Pro-Link Factor 55
Pro-Link Factor 55
Saw this over on expo and thought some of ya'll may like to take a look at it. It does seem to be a nice way to add a D-ring to the winch.
http://www.factor55.com/index.php
“Do not go where the path may lead; go instead where there is no path and leave a trail”
-Ralph Waldo Emerson
Re: Pro-Link Factor 55
I used to wonder why they didn't put a steel cable thimble on our winch end loop. I put one on mine & the first time i used it, it bent the snot out of it. Now i know why !
I just installed the Prolink on my 2014. I had to slightly bend the upper part of the bumper opening.
- IMG_2336.jpeg (22.57 KiB) Viewed 2814 times
- IMG_2339.jpeg (30.43 KiB) Viewed 2814 times
- whitey
Why wouldn't you use a shackle on the end of your hook? I haven't seen any signs of stress on my hook in 8 years. Anyone hear of hook failures? I've had some pretty hard pulls in the past and one may have a 5 ton truck involved in my future?
- jeep_boy02
Most of the time the hooks are fine. There have been some issues (not PW specific) but mainly could have been avoided with maintainence or proper techniques. A shackle is safer and stronger but a hook isn't wrong.
I've made plenty of pulls without issue, including pulling a 10k+ pound tractor up a steep incline with flat tires. I do usually use a shackle to attach hook to strap or whatever. I would mention I would not advise hooking strap ends directly to hook. That has always made me shudder when I see it for some reason.
I brought this up earlier- here's a good read on the product. http://forum.powerwagonregistry.org/vie ... f=2&t=2661
If the eye on your strap fits inside the hook, then your strap is probably not big enough.I would not advise hooking strap ends directly to hook.
- whitey
after looking my stuff over I don't have any worries. I've had my line on 2 snatch blocks with pulls no one else wanted to try and don't see any distortion or fatigue. I'm good. It's not a part that will strand me or someone else either.
