Sliders
Re: Sliders
white knuckle seems like the go to around here. they will be my choice.
if im not mistaken, the aluminess are not frame mounted?
and depending on your use, frame mounted sliders may be the most sturdy
Re: Sliders
I went with wk sliders. Drilling all those holes in the body to mount the aluminess ones scared the hell out of me. The rockers would be swiss cheese in no time around here with all the road salt in the winter.
The aluminess offer a lot more ground clearance per se, but really the wk ones dont hang anywhere near as low as the frame does, sooooooo....
 Re: Sliders
 Re: Sliders
			The Aluminess is aluminum, so it's soft metal. You'll put so nice grooves in them if you slide across enough rocks. I have their bumper. And I got some nice marks on the bottom of it.
- Low_Sky
Re: Sliders
Aluminess sliders are steel. The problem with them is that they mount to the body just like step bars. Maybe OK for incidental bump protection, but not OK for hard hits and intentional use.RustyPW wrote:The Aluminess is aluminum, so it's soft metal. You'll put so nice grooves in them if you slide across enough rocks. I have their bumper. And I got some nice marks on the bottom of it.
 Re: Sliders
 Re: Sliders
			When did they change them. They was aluminum.Low_Sky wrote: ↑Thu Jan 17, 2019 4:34 pmAluminess sliders are steel. The problem with them is that they mount to the body just like step bars. Maybe OK for incidental bump protection, but not OK for hard hits and intentional use.RustyPW wrote:The Aluminess is aluminum, so it's soft metal. You'll put so nice grooves in them if you slide across enough rocks. I have their bumper. And I got some nice marks on the bottom of it.
Re: Sliders
I knew the aluminess were made out of steel, but I did not know they mounted to the body. That doesn't exactly seem like the best place to anchor rock sliders haha. The white knuckle ones sure look awesome.
Sliders
Believe the aluminess sliders have always been steel. Everything else they make is aluminum I believe. Their Ram sliders are an exception.
There’s pictures you can google of a truck identical to mine that got t-boned in an intersection by a hatchback. The front of the car was annihilated; the Aluminess slider had a bent in it and there was a dent in the door. I think there are pros and cons to either. For occasional hits aluminess is just fine.
Re: Sliders
This was the crash. Note that is an AFTER pic, see the tiny bend in the sliders and ding under the door?
I haven’t worked with aluminess sliders. Just don’t discount them because they’re body mounted. If you beat on your truck get frame mounted sliders. Otherwise for occasional use the body mounted units work.
- Low_Sky
Re: Sliders
That truck is the same one on their website. Possibly the only set they’ve ever sold? HahaDamageWagon wrote:
Re: Sliders
The body mount can be strong enough. There is the hardcore Jeep trick where you cut away the rocker panels and weld in DOM tubing.
But the WK have been fine in my limited experience of being dragged over rock by a winch.
						- Low_Sky
Re: Sliders
A length of DOM tube welded along the full length of a ~4000 lbs Jeep rocker is not an “apples to apples” comparison with a bolt-on slider secured to sheet metal on an 8000 lbs truck.KevinABQ wrote:The body mount can be strong enough. There is the hardcore Jeep trick where you cut away the rocker panels and weld in DOM tubing.
Re: Sliders
To the OP - go with the .188 DOM White Knuckle sliders, they are the strongest frame mounted option!  Fast and easy install without any drilling anywhere!
Re: Sliders
WK is a really nice product.  I am very pleased with mine and have definitely used them hard.
						Re: Sliders
I guess I'd be fine with either, but will go with WK. the biggest obstacle now is convincing the wife that I need a $1000 mod on my truck. Some mods are easy to hide, but not this one haha.
Re: Sliders
Where you gonna find a set for $1000?! LOL
Re: Sliders
- Low_Sky
Re: Sliders
Show her how much damage to the rocker panels and doors costs to repair. They pay for themselves the first time they take a good bump.
Re: Sliders
Haha good point. I will also show her the pictures damagewagon posted of that wreck. Safety first!
Re: Sliders
This, this "good enough for Jeeps" thing comes up all the time when people are talking about the Randy Elis sliders. There is also another HUGE difference, and that's the gap between the frame and the body. Look under a Jeep and notice how much closer it is to the pinch seam. A lot of Jeep sliders, while mounting there, also go back to the frame.Low_Sky wrote: ↑Thu Jan 17, 2019 7:23 pmA length of DOM tube welded along the full length of a ~4000 lbs Jeep rocker is not an “apples to apples” comparison with a bolt-on slider secured to sheet metal on an 8000 lbs truck.KevinABQ wrote:The body mount can be strong enough. There is the hardcore Jeep trick where you cut away the rocker panels and weld in DOM tubing.
It's def not apples and oranges.
				EasyDoesIt
Re: Sliders
This may come off like I'm some cranky old guy but I promise its with good intentions.
Can we sticky this or another thread that shows all the options for PW Rock Sliders? Seems like this comes up every couple months and maybe its because we don't have a sticky that shows all the options and pros/cons of each.
Don't get me wrong, I'm a fan of the site traffic and a firm believer of theirs no such thing as a stupid question but it would be nice to be able to post a simple link when someone asks this question. At least if they have specific questions, they can always start a new thread.
						Re: Sliders
Anyone know what sliders these are? In the video he says they are a knockoff of WK but I can't find anything on them.
https://m.youtube.com/watch?v=3ZtVvBpI2o0
- Low_Sky
Re: Sliders
Looks like the guy who welded mine is still in business and relocated from Farmington. I don’t have his contact info any more, unfortunately.Lazarus wrote:Anyone know what sliders these are? In the video he says they are a knockoff of WK but I can't find anything on them.
Re: Sliders
Oh yeah, David bought his used on CL somewhere near Aurora, CO.Lazarus wrote: ↑Mon Jan 21, 2019 11:01 amAnyone know what sliders these are? In the video he says they are a knockoff of WK but I can't find anything on them.
If you want WK sliders hold tight, they're going to be one of our title sponsors for PWIM and we're working out a discount. Should finalize this week.
- Low_Sky
Re: Sliders
When I bought mine there were two sets in circulation. If those were a CL pickup, they may be my sliders’ long lost twins.BoldAdventure wrote:Oh yeah, David bought his used on CL somewhere near Aurora, CO.Lazarus wrote: ↑Mon Jan 21, 2019 11:01 amAnyone know what sliders these are? In the video he says they are a knockoff of WK but I can't find anything on them.
Mine are a little worse for wear, looks like their twins are living an easy life.
