These Damn Lockers Are Going To Lead Me to Drink!
Re: These Damn Lockers Are Going To Lead Me to Drink!
I have never understood why they would put a magnetic switch and a heavy duty magnetic coil actuator in an environment that is... well um, contaminated with metallic sludge all the time. I can't help but think keeping the oil clean is going to be key to properly operating sludge free lockers.
So Far my Filtermag GP101 differential magnets have done an excellent job of removing the fine metal particulates from the oil. I can tell from the fact that I have minimal to no deposits of sludge on the locker magnetic sensors. I do notice that the Filtermag magnet is covered in sludge so I bought two more to increase the surface area for sludge contamination collection the next time I change my differential fluids.
I can't help but believe the pinion and axle seals will benefit as well since the metal abrasive material is being removed from the oil before it can act as an abrasive on the seals and other internal parts.
I agree there could have been better location for locker CPU. I agree that hard wire works too. Still when you turn on hard wired locker how do you actually know it engaged? You don't. It might have or might not. That is until you raise one leg in the air and find out where you have power on opposite wheel or not. But that simple act of loosing traction on one side may allow for splines to engage. Hence problem others face goes by unnoticed by ignorance not by improved function. There is no little flashing light to wary about.Chiprat1 wrote:before there was the Dumb Bar and elect circuit board 12 inches on the ground outside!!!!! there we standard electrical lockers that many people used. the same lockers we have just without the Dumb Bar. Hard wire works and has no draw backs.
If you want to read my License plate, you must have lockers that work...
I'll get one of those magnets next time I change diff lube.
Smart bar came today....so once I get some warmer weather il install it...also with the by pass ...I added a weather plug connection so if I have to bring it to the dealer I can remove it from the switch....I just hope this will solve my issue..
Has anybody come across the factory service manual for the 4th gen 2500s yet? I have it for the 1500. Or maybe the 08 / 09? I can probably figure out the factory switch by looking at the wiring diagrams.
From the 2002-2008 FSM, had to do 3 screen captures to get the whole thing...Dawizman wrote:Has anybody come across the factory service manual for the 4th gen 2500s yet? I have it for the 1500. Or maybe the 08 / 09? I can probably figure out the factory switch by looking at the wiring diagrams.
click to enlarge
- GunniPWguy
We will be watchin. Hope it solves the problem.w2dodge wrote:Smart bar came today....so once I get some warmer weather il install it...also with the by pass ...I added a weather plug connection so if I have to bring it to the dealer I can remove it from the switch....I just hope this will solve my issue..
I hope so also...I have a spare one now . I just might open it up seeGunniPWguy wrote:We will be watchin. Hope it solves the problem.w2dodge wrote:Smart bar came today....so once I get some warmer weather il install it...also with the by pass ...I added a weather plug connection so if I have to bring it to the dealer I can remove it from the switch....I just hope this will solve my issue..
what's it all about
Thanks for posting that. I have a feeling that the factory switch won't be too easy to make work with hard wired lockers. When I get my truck back from the dealer, I will test it out & see what I can figure out. I'm thinking it might involve a custom circuit board to make things work. It's doable, but might be more hassle than it's worth. Also, the 4th gen trucks might be different than that diagram, making it more complicated. I'll do my best, but no guarantees.
Sent from my HTC Desire HD using Tapatalk 2
click to enlarge
The Dodge AAM 10.5 is different from the GM jobbie.TwinStick wrote:N2DFIRE
Is it the same as the GM AAM 10.5" 14 bolt ??? Because i can't seem to find it listed anywhere. Post a link please.
- GunniPWguy
figured I would put this link here too. Don't forget the whole locker action can be out of whack without the proper locker magnet cleaning and gap!
http://www.dodgetalk.com/forums/showthr ... magnet+gap
Lots of good info...RustyPW wrote:The Dodge AAM 10.5 is different from the GM jobbie.TwinStick wrote:N2DFIRE
http://www.powertodeliver.com/technical ... t-diagrams
last comment, I have had my truck since 2006, I know when they are locked with or with out a light. I had a Detroit locker for 9 years....you knew when that think locked. Just saying. Once you go "Hard" (Wired) you will never go back.PWRider wrote:I agree there could have been better location for locker CPU. I agree that hard wire works too. Still when you turn on hard wired locker how do you actually know it engaged? You don't. It might have or might not. That is until you raise one leg in the air and find out where you have power on opposite wheel or not. But that simple act of loosing traction on one side may allow for splines to engage. Hence problem others face goes by unnoticed by ignorance not by improved function. There is no little flashing light to wary about.Chiprat1 wrote:before there was the Dumb Bar and elect circuit board 12 inches on the ground outside!!!!! there we standard electrical lockers that many people used. the same lockers we have just without the Dumb Bar. Hard wire works and has no draw backs.
2006 Power Wagon
5th Wheel hitch
5th Wheel hitch
OK, i am subscribed now.
We got our first taste of the white stuff on Saturday night. Was headed home as I was very disappointed because the snow was not sticking and no one needed help
Coming up on the turn that goes into my neighborhood and what do you know, a car is in the ditch
I whip around and hook up to pull them out. I throw "OX" in 4 low and hit the rear locker and what do you know
SERVE 4X4 light comes on
Went outside today drove her in the grass and tried it again, same issue. Sway bar works fine, as soon as I switch to the rear locker the serve 4x4 light comes on
anyone have this issue?
I took the connectors off and cleaned them out, also added dialectric greese with no change
Power Wagon Registry #47
- Thuren steering upgrade
"The" Wifes Car
"Faith" 2014 Charger RT Max
My Toy
"VISCO" 2013 196CC Tidewater
"The" Wifes Car
My Toy
- VA_Wagon Man
Danny, we have the same year trucks......my locker wires were broke about an inch from where the locker plugs into the rear differential. It was so small i could barely see it. Check yours. The break was similar to how our rear door speaker wires break going from the b pillar to the rear door.
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
My '05 wires broke in the same place...VA_Wagon Man wrote:Danny, we have the same year trucks......my locker wires were broke about an inch from where the locker plugs into the rear differential. It was so small i could barely see it. Check yours. The break was similar to how our rear door speaker wires break going from the b pillar to the rear door.
Thanks for the help, I remember when I brought "OX" that I had to work on the rear locker. Thanks for reminding me. The culprit was right in front of my eyes all this time.
MAN I LOVE THIS SITE
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
I am going to work on her this weekend, will let you know if this fixes my problems
"The" Wifes Car
My Toy
"The" Wifes Car
My Toy
- VA_Wagon Man
I bought an extra pigtail assembly from dodge for like $25 and keep it in the truck as a spare.
Long Gone:
Well I picked up the pw from the dealership last night,they made the repair on my serv4wd rr issue,here's a pic of the things they swapped...it was under warranty and I just paid 100$ deductible...so I was very happy...but that didn't last long..early Tuesday morning at about 2am I hear a loud boom..i get up to see what the hell it was..some a..hole recked my go to work truck...it's parked in street in front of my house...and this clown was trying to start his car to scram..here's a pic...he pushed it back 10 feet onto the sidewalk.
that sucks! when it rains it pours...
mike
mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Gooseneck
2016 Volvo XC90
Especially when price of gas is so damn high....
Ouch! Drunk I assume?
- GunniPWguy
Wow! That is Fu*@ed up! sorry to hear/see that. Glad your lockers are working again though.
He said he had a couple of drinks,but he was trying to light a cigarette and dropped it on his lap...cops gave him sobriety test and he pass it...but got a summons for reckless driving...it just blowsvanished wrote:Ouch! Drunk I assume?
