These Damn Lockers Are Going To Lead Me to Drink!
azracer
Re: These Damn Lockers Are Going To Lead Me to Drink!
Post by azracer » Tue Jan 22, 2013 4:27 pm
I have never understood why they would put a magnetic switch and a heavy duty magnetic coil actuator in an environment that is... well um, contaminated with metallic sludge all the time. I can't help but think keeping the oil clean is going to be key to properly operating sludge free lockers.
So Far my Filtermag GP101 differential magnets have done an excellent job of removing the fine metal particulates from the oil. I can tell from the fact that I have minimal to no deposits of sludge on the locker magnetic sensors. I do notice that the Filtermag magnet is covered in sludge so I bought two more to increase the surface area for sludge contamination collection the next time I change my differential fluids.
I can't help but believe the pinion and axle seals will benefit as well since the metal abrasive material is being removed from the oil before it can act as an abrasive on the seals and other internal parts.
PWRider
Post by PWRider » Tue Jan 22, 2013 4:51 pm
Chiprat1 wrote:before there was the Dumb Bar and elect circuit board 12 inches on the ground outside!!!!! there we standard electrical lockers that many people used. the same lockers we have just without the Dumb Bar. Hard wire works and has no draw backs.
If you want to read my License plate, you must have lockers that work... :)
I agree there could have been better location for locker CPU. I agree that hard wire works too. Still when you turn on hard wired locker how do you actually know it engaged? You don't. It might have or might not. That is until you raise one leg in the air and find out where you have power on opposite wheel or not. But that simple act of loosing traction on one side may allow for splines to engage. Hence problem others face goes by unnoticed by ignorance not by improved function. There is no little flashing light to wary about.
I'll get one of those magnets next time I change diff lube.
w2dodge
Post by w2dodge » Tue Jan 22, 2013 7:59 pm
Smart bar came today....so once I get some warmer weather il install it...also with the by pass ...I added a weather plug connection so if I have to bring it to the dealer I can remove it from the switch....I just hope this will solve my issue..
Dawizman
Post by Dawizman » Tue Jan 22, 2013 8:18 pm
Has anybody come across the factory service manual for the 4th gen 2500s yet? I have it for the 1500. Or maybe the 08 / 09? I can probably figure out the factory switch by looking at the wiring diagrams.
Post by cruz » Tue Jan 22, 2013 8:30 pm
Dawizman wrote:Has anybody come across the factory service manual for the 4th gen 2500s yet? I have it for the 1500. Or maybe the 08 / 09? I can probably figure out the factory switch by looking at the wiring diagrams.
From the 2002-2008 FSM, had to do 3 screen captures to get the whole thing...
click to enlarge
GunniPWguy
Post by GunniPWguy » Tue Jan 22, 2013 9:01 pm
w2dodge wrote:Smart bar came today....so once I get some warmer weather il install it...also with the by pass ...I added a weather plug connection so if I have to bring it to the dealer I can remove it from the switch....I just hope this will solve my issue..
We will be watchin. Hope it solves the problem. :popcorn:
w2dodge
Post by w2dodge » Tue Jan 22, 2013 9:17 pm
I hope so also...I have a spare one now . I just might open it up see
what's it all about
Dawizman
Post by Dawizman » Tue Jan 22, 2013 9:32 pm
Thanks for posting that. I have a feeling that the factory switch won't be too easy to make work with hard wired lockers. When I get my truck back from the dealer, I will test it out & see what I can figure out. I'm thinking it might involve a custom circuit board to make things work. It's doable, but might be more hassle than it's worth. Also, the 4th gen trucks might be different than that diagram, making it more complicated. I'll do my best, but no guarantees.
click to enlarge
Sent from my HTC Desire HD using Tapatalk 2
Post by RustyPW » Tue Jan 22, 2013 10:00 pm
TwinStick wrote:N2DFIRE
Is it the same as the GM AAM 10.5" 14 bolt ??? Because i can't seem to find it listed anywhere. Post a link please. :cheers:
The Dodge AAM 10.5 is different from the GM jobbie.
GunniPWguy
Post by GunniPWguy » Tue Jan 22, 2013 10:10 pm
figured I would put this link here too. Don't forget the whole locker action can be out of whack without the proper locker magnet cleaning and gap!
http://www.dodgetalk.com/forums/showthr ... magnet+gap
Post by cruz » Tue Jan 22, 2013 10:19 pm
Lots of good info...
http://www.powertodeliver.com/technical ... t-diagrams
Chiprat1
Post by Chiprat1 » Tue Jan 22, 2013 10:19 pm
last comment, I have had my truck since 2006, I know when they are locked with or with out a light. I had a Detroit locker for 9 years....you knew when that think locked. Just saying. Once you go "Hard" (Wired) you will never go back.
2006 Power Wagon
5th Wheel hitch
:winchmob:
RedMan
Post by RedMan » Mon Feb 18, 2013 8:59 pm
OK, i am subscribed now.
We got our first taste of the white stuff on Saturday night. Was headed home as I was very disappointed because the snow was not sticking and no one needed help :angry:
Coming up on the turn that goes into my neighborhood and what do you know, a car is in the ditch :excited:
I whip around and hook up to pull them out. I throw "OX" in 4 low and hit the rear locker and what do you know :wtf: SERVE 4X4 light comes on :box:
Went outside today drove her in the grass and tried it again, same issue. Sway bar works fine, as soon as I switch to the rear locker the serve 4x4 light comes on
anyone have this issue?
I took the connectors off and cleaned them out, also added dialectric greese with no change :digahole:
Power Wagon Registry #47
- Thuren steering upgrade
"The" Wifes Car
"Faith" 2014 Charger RT Max
My Toy
"VISCO" 2013 196CC Tidewater
VA_Wagon Man
Post by VA_Wagon Man » Tue Feb 19, 2013 8:20 am
Danny, we have the same year trucks......my locker wires were broke about an inch from where the locker plugs into the rear differential. It was so small i could barely see it. Check yours. The break was similar to how our rear door speaker wires break going from the b pillar to the rear door.
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
vanished
Post by vanished » Tue Feb 19, 2013 9:54 am
VA_Wagon Man wrote:Danny, we have the same year trucks......my locker wires were broke about an inch from where the locker plugs into the rear differential. It was so small i could barely see it. Check yours. The break was similar to how our rear door speaker wires break going from the b pillar to the rear door.
My '05 wires broke in the same place... :cry:
RedMan
Post by RedMan » Tue Feb 19, 2013 9:17 pm
Thanks for the help, I remember when I brought "OX" that I had to work on the rear locker. Thanks for reminding me. The culprit was right in front of my eyes all this time.
MAN I LOVE THIS SITE :excited:
"The" Wifes Car
My Toy
Post by TwinStick » Tue Feb 19, 2013 9:58 pm
Glad you got it fixed.
RedMan
Post by RedMan » Wed Feb 20, 2013 8:44 pm
I am going to work on her this weekend, will let you know if this fixes my problems :poke:
"The" Wifes Car
My Toy
VA_Wagon Man
Post by VA_Wagon Man » Wed Feb 20, 2013 10:23 pm
I bought an extra pigtail assembly from dodge for like $25 and keep it in the truck as a spare.
Long Gone:
w2dodge
Post by w2dodge » Tue Feb 26, 2013 5:29 pm
Well I picked up the pw from the dealership last night,they made the repair on my serv4wd rr issue,here's a pic of the things they swapped...it was under warranty and I just paid 100$ deductible...so I was very happy...but that didn't last long..early Tuesday morning at about 2am I hear a loud boom..i get up to see what the hell it was..some a..hole recked my go to work truck...it's parked in street in front of my house...and this clown was trying to start his car to scram..here's a pic...he pushed it back 10 feet onto the sidewalk.
MSCH2112
Post by MSCH2112 » Tue Feb 26, 2013 5:41 pm
that sucks! when it rains it pours...
mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
w2dodge
Post by w2dodge » Tue Feb 26, 2013 8:28 pm
Especially when price of gas is so damn high....
vanished
Post by vanished » Tue Feb 26, 2013 8:40 pm
Ouch! Drunk I assume?
GunniPWguy
Post by GunniPWguy » Tue Feb 26, 2013 9:13 pm
Wow! That is Fu*@ed up! sorry to hear/see that. Glad your lockers are working again though. :)
w2dodge
Post by w2dodge » Tue Feb 26, 2013 9:19 pm
vanished wrote:Ouch! Drunk I assume?
He said he had a couple of drinks,but he was trying to light a cigarette and dropped it on his lap...cops gave him sobriety test and he pass it...but got a summons for reckless driving...it just blows
