Post by Bill2014 » Mon Dec 03, 2018 9:44 am
Low_Sky wrote:
Mon Dec 03, 2018 3:33 am
Wheel turned to the right, trying to climb the ice shelf, sliding along and ramming into the end of the shelf.
How low was your tire pressure?
There's always a trade-off between traction and keeping the bead seated :D
Post by Low_Sky » Mon Dec 03, 2018 11:39 am
20 psi
Post by Low_Sky » Mon Dec 03, 2018 11:43 am
And I’m “ain’t skeered” about losing a bead. First time I’ve done it on this truck, but that’s why I carry full tire repair tools on the trail.
Reseated it and drove it the rest of the way off the trail. Had to put the spare on when I got back to the highway. Was getting out of balance from the ~gallon of water and sand inside it.
Cleaned it out yesterday and we’re back to 100%. I even learned that TPMS sensors are submersible, at least for a little while. This one was dunked for as long as it took me to pull cable and winch out, and when I put the wheel back on the truck and drove it around the neighborhood it came back to life.
Post by Colibri » Tue Dec 04, 2018 8:55 am
Very cool! Always love your pics low sky.
Post by TankerZak » Fri Dec 07, 2018 9:15 pm
Snow day!Image
Post by Colibri » Fri Dec 07, 2018 10:25 pm
WOW. That’s beautiful
Mule
Post by Mule » Sat Dec 08, 2018 3:26 am
Snow week? 8-)
Just about packed, got most of the course work gone through. Heading north for a week of snow dork training.
First load-up with the new glides installed in the bed.
Wide-Glides are just the right length, from back edge of the bed to the front of the carbide when the sled's in the bed. :lockedandloaded:
Track and ramp catches on the tailgate glides when I slide the sled over to shove the ramp under it. Otherwise i'm happy with this so far.
Post by Bill2014 » Sat Dec 08, 2018 5:52 am
A longer bed might really help your cause :D
Mule
Post by Mule » Sat Dec 08, 2018 4:34 pm
Short-bed's good enough. :lol:
Image Image
Image Image
Just me, for a week. :jawdrop: :rofl:
Mule
Post by Mule » Mon Dec 17, 2018 3:02 pm
New radiator. Had some issues overheating on long pulls with a trailer, that with the same trailer didn't used to overheat the truck.
Also had a coolant smell in the cab... Thought it was a leaking heater core, shop said leaking and inefficient radiator.
They also serviced t-case (fluid was dark), replaced rear diff seal (again, apparently it was leaking), and the gas struts on the hood.
Hopefully good for the season ... because I need a new track on my sled. :(
Post by TankerZak » Tue Dec 18, 2018 10:39 am
Wheels on. Thuren Bumper is next. (Already in the garage).Image
Post by Reloaderguy » Tue Dec 18, 2018 10:43 am
That's a nice wheel.
Post by TankerZak » Tue Dec 18, 2018 10:49 am
LOL! Wonder where I got them...
AlaskaTRX
Post by AlaskaTRX » Tue Dec 18, 2018 10:51 am
20 psi
I’m nervous to ask what a decent beadlock would cost in an 8-lug, 17” wheel. I wonder if anyone has tried running Humvee tires and wheels, and the bolt pattern is the same...
Post by TankerZak » Tue Dec 18, 2018 10:54 am
20 psi
About 2500 for a set of 5 beadlocks. And you can run Hummer wheels but you have to get them bored out. There was a website that sold them refurbished and bored out that I saw a year or two ago. Ymmv.
Post by DamageWagon » Tue Dec 18, 2018 5:31 pm
AlaskaTRX wrote:
Bill2014 wrote: How low was your tire pressure?
20 psi
If Low Sky gives the go-ahead I’ll make you guys a group deal.
HMMWV wheels will not work on our trucks. The wheels cannot be made to fit over the brake calipers. If you COULD get them on they are a serious hazard, if you get a stone lodged between the caliper and the wheel you can slice the wheel in half.
Post by Reloaderguy » Tue Dec 18, 2018 6:40 pm
20 psi
I'm running 25/20 cold on the street. They come up to 29/24 hot.
I think base price on TR's is around $460ea. Once you add in colors you're a lot closer to $600ea.
Post by Colibri » Wed Dec 19, 2018 12:18 am
Humvee wheels are 16.5” as damagewagon said they won’t fit. Tire selection would be crap if they did though
Kalemw86
Post by Kalemw86 » Fri Dec 21, 2018 9:28 pm
Just got her 2018
1pieceatatime
Post by 1pieceatatime » Sun Dec 23, 2018 10:36 pm
Had to use the winch today! Got a little too close to edge of rut and it gave out beneath RR, got hung up on rear differential.
LagunaH1
Post by LagunaH1 » Sun Dec 23, 2018 10:45 pm
Glad you didn't get stuck. I'm curious: What did you use for anchor point?
2016 RAM 2500 Power Wagon SLT
NR6E
Post by Low_Sky » Sun Dec 23, 2018 11:16 pm
1pieceatatime wrote:Had to use the winch today! Got a little too close to edge of rut and it gave out beneath RR, got hung up on rear differential.
Be honest, were you trying to set up a gratuitous glamor flex pose?
Post by Low_Sky » Sun Dec 23, 2018 11:22 pm
40s and snow were meant to be together.
Post by RustyPW » Sun Dec 23, 2018 11:42 pm
I'm jealous!
I want 40'S. :drool:
1pieceatatime
Post by 1pieceatatime » Mon Dec 24, 2018 3:30 pm
Truck looks great in the snow, Low_Sky.
I ended up winching off another truck. Considered snatch strap, but figured winch was safest option since I didn’t really know how bad it was hung up.
