37" tires with 4.10 for those who do have
Re: 37" tires with 4.10 for those who do have
Post by Colibri » Fri Aug 17, 2018 7:56 pm
adeluca73 wrote:
Fri Aug 17, 2018 3:44 pm
Fri Aug 17, 2018 3:24 pm
Bill2014 wrote:
Fri Aug 17, 2018 8:51 am
If you only do work in the forward direction, it reduces to a question of optimization...
If backing something heavy up a winding hill in 4Lo is in the picture, I would think twice about the "weaker" gear set.
I've been in 4Lo reverse with the wheels taking turns breaking loose - stock gears - hoping I don't hear a snap and have things come to a grinding halt. :notworthy:
If it wasn't for the strength concern, I may have regeared even with the 33's. (for the way I use the PW)
On the other hand, the Power Wagons aren't high torque diesels so maybe it doesn't matter.
I am on stock size tires as I think you are, and even with those I would like 4.56's, if not 4.88's. The trans gears are just so high.
When the jump to 37's comes I think I will go to 5.13's.
Funny—all this talk of gearing and tires, at one point 4.88’s & 37’s were like the holy grail step-up for the Best-Gen trucks, put us on par or above with the ‘13 and older crowd who mostly gravitate to 35’s and keep their 4.56’s. Now the move is to 39/40” tires and 5.13’s—and I’ve been secretly discussing with my inner engineer the virtue of abandoning the 37” experience and moving down to lowly 35’s ( HUSH YOUR MOUTH) when these Nittos are done :jawdrop:
The unsprung weight difference, added driveline stress, and steep increase in rolling moment of inertia haunts my nerd alter-ego, but the cool kid in me wants 5.13’s and 40’s (STILL YOU MIND, DONT LISTEN TO THOSE MOAB HERETICS AND GYPSIES, THEY’ll PILFER YOUR TREASURE AND PLUNDER YOUR TRUCK) so i war with my innersef, but i think 35’s and 4.88’s look pretty great for all around use....maybe a bit higher RPM at 75mph than I’d like, but I’ll take that over the fear of constant brake fade, and NO, I’M NOT INSTALLING HYDRO ASSIST STEERING, OR A BIGGER MASTER CYLINDER AND HIGH CAPACITY STEEL BRAUDED LINES—GET THEE BEHIND ME SATAN
Cleopatra queen of denial lol
Post by Low_Sky » Fri Aug 17, 2018 9:48 pm
4.88s and 35s, think of the pep!
Post by Reloaderguy » Fri Aug 17, 2018 10:07 pm
Do you think an AEV snorkel is tall enough to get across denial?
Post by olyelr » Fri Aug 17, 2018 10:23 pm
Mister reloaderman, its an intake that is raised... not to be mistaken for a snorkel.
Post by adeluca73 » Sat Aug 18, 2018 2:19 am
Post by Colibri » Sat Aug 18, 2018 9:36 am
Hahahaha
Tejas
Post by Tejas » Sun Nov 11, 2018 5:58 pm
Who do you guys recommend for a R&P Gear swap in the Houston area?
Post by Colibri » Mon Nov 12, 2018 10:55 am
Either gulf coast crawl shop/javiers complete auto
Or
Brave motorsports
Tejas
Post by Tejas » Mon Nov 12, 2018 4:56 pm
Or
Brave motorsports
I forgot about Javier's, he did some work on our LC and he did the entire engine/tranny swap on my father's FJ40. I'll get with him when it's time.
Post by Colibri » Mon Nov 12, 2018 6:00 pm
Small world lol. Yeah he’s had some really nice FJ40’s come through his shop. If you end up needing any advanced fabrication work done go with brave
