Cleopatra queen of denial loladeluca73 wrote: ↑Fri Aug 17, 2018 3:44 pmFunny—all this talk of gearing and tires, at one point 4.88’s & 37’s were like the holy grail step-up for the Best-Gen trucks, put us on par or above with the ‘13 and older crowd who mostly gravitate to 35’s and keep their 4.56’s. Now the move is to 39/40” tires and 5.13’s—and I’ve been secretly discussing with my inner engineer the virtue of abandoning the 37” experience and moving down to lowly 35’s ( HUSH YOUR MOUTH) when these Nittos are doneolyelr wrote: ↑Fri Aug 17, 2018 3:24 pmBill2014 wrote: ↑Fri Aug 17, 2018 8:51 amIf you only do work in the forward direction, it reduces to a question of optimization...
If backing something heavy up a winding hill in 4Lo is in the picture, I would think twice about the "weaker" gear set.
I've been in 4Lo reverse with the wheels taking turns breaking loose - stock gears - hoping I don't hear a snap and have things come to a grinding halt.
If it wasn't for the strength concern, I may have regeared even with the 33's. (for the way I use the PW)
On the other hand, the Power Wagons aren't high torque diesels so maybe it doesn't matter.
I am on stock size tires as I think you are, and even with those I would like 4.56's, if not 4.88's. The trans gears are just so high.
When the jump to 37's comes I think I will go to 5.13's.![]()
The unsprung weight difference, added driveline stress, and steep increase in rolling moment of inertia haunts my nerd alter-ego, but the cool kid in me wants 5.13’s and 40’s (STILL YOU MIND, DONT LISTEN TO THOSE MOAB HERETICS AND GYPSIES, THEY’ll PILFER YOUR TREASURE AND PLUNDER YOUR TRUCK) so i war with my innersef, but i think 35’s and 4.88’s look pretty great for all around use....maybe a bit higher RPM at 75mph than I’d like, but I’ll take that over the fear of constant brake fade, and NO, I’M NOT INSTALLING HYDRO ASSIST STEERING, OR A BIGGER MASTER CYLINDER AND HIGH CAPACITY STEEL BRAUDED LINES—GET THEE BEHIND ME SATAN
37" tires with 4.10 for those who do have
Re: 37" tires with 4.10 for those who do have
- Low_Sky
4.88s and 35s, think of the pep!adeluca73 wrote:Funny—all this talk of gearing and tires, at one point 4.88’s & 37’s were like the holy grail step-up for the Best-Gen trucks, put us on par or above with the ‘13 and older crowd who mostly gravitate to 35’s and keep their 4.56’s. Now the move is to 39/40” tires and 5.13’s—and I’ve been secretly discussing with my inner engineer the virtue of abandoning the 37” experience and moving down to lowly 35’s ( HUSH YOUR MOUTH) when these Nittos are doneolyelr wrote: ↑Fri Aug 17, 2018 3:24 pmBill2014 wrote: ↑Fri Aug 17, 2018 8:51 amIf you only do work in the forward direction, it reduces to a question of optimization...
Do you think an AEV snorkel is tall enough to get across denial?Colibri wrote: ↑Fri Aug 17, 2018 7:56 pmCleopatra queen of denial loladeluca73 wrote: ↑Fri Aug 17, 2018 3:44 pmFunny—all this talk of gearing and tires, at one point 4.88’s & 37’s were like the holy grail step-up for the Best-Gen trucks, put us on par or above with the ‘13 and older crowd who mostly gravitate to 35’s and keep their 4.56’s. Now the move is to 39/40” tires and 5.13’s—and I’ve been secretly discussing with my inner engineer the virtue of abandoning the 37” experience and moving down to lowly 35’s ( HUSH YOUR MOUTH) when these Nittos are done![]()
Mister reloaderman, its an intake that is raised... not to be mistaken for a snorkel.
Reloaderguy wrote: ↑Fri Aug 17, 2018 10:07 pmDo you think an AEV snorkel is tall enough to get across denialColibri wrote: ↑Fri Aug 17, 2018 7:56 pmCleopatra queen of denial loladeluca73 wrote: ↑Fri Aug 17, 2018 3:44 pm
- 0EB84086-4DB8-422D-B836-07BE223FFADF.jpeg (35.74 KiB) Viewed 3793 times
Hahahaha
Who do you guys recommend for a R&P Gear swap in the Houston area?
Either gulf coast crawl shop/javiers complete auto
Or
Brave motorsports
Or
Brave motorsports
Small world lol. Yeah he’s had some really nice FJ40’s come through his shop. If you end up needing any advanced fabrication work done go with brave
