Hubcentric rings
gen1runner
Hubcentric rings
Post by gen1runner » Wed Oct 24, 2018 8:18 am
Question for those running aftermarket wheels. I was looking into get a set of XD addict 2s. I noticed they have a hub bore of 125 and our trucks have a hub dia of 120.9. was just wondering if any of you guys had hubcentric rings installed to make up that 4mm difference? Doing the math its roughly 1/16" of an inch space on a side for clearance which seem a little much.
Re: Hubcentric rings
Post by RustyPW » Wed Oct 24, 2018 6:17 pm
I have CenterLine rims. Never had or used the rings.
Alakablamo
Post by Alakablamo » Tue Oct 30, 2018 8:31 am
I have the centering rings for my aftermarket wheels on my Ram 1500. The ones I have are a nylon composite material, which is fine because they won't galvanically corrode to the wheel. I have push-through center caps, so the rings I have are sized for the cap bore (106mm) and not the wheel bore (108mm).
I recommend them for anyone using aftermarket wheels to maintain the better wheel-centering of a hub-centric fit.
gen1runner
Post by gen1runner » Wed Oct 31, 2018 6:46 am
I had them on my Ram as well but it was a significant more space between the bore and hub than on my wagon. I would guess I would need someone to make a custom ring and even then a .062" walled ring probably won't be necessary
Post by Bill2014 » Wed Oct 31, 2018 3:03 pm
If you use your truck in such a way that you find you are airborne from time-to-time, then you might have a reason to be concerned. If that is not the case, then absolutely don't worry about the wheel hub oversize. Do make sure your lug nuts are torqued correctly!
gen1runner
Post by gen1runner » Mon Nov 05, 2018 9:34 am
Well I threw on my new wheels all has been well. ImageImageImage
Post by olyelr » Mon Nov 05, 2018 1:13 pm
:rockon:
