Memorial Day Sale!
Here’s your chance to save up to $100 on two of the best mods for a Power Wagon:
The Standard “Locker Bypass”: Which gives you full control of the lockers using the factory dash knob, at any speed, in any transfer case range. The normal price for a “Locker Bypass” is $450 - This week only, a standard Locker Bypass is only $399! (The factory sway bar disconnect and switches still work according to the factory protocol). Works on all 2005-2018 Power Wagons.
The "Full SmartBar Bypass": This system would give you full control of the lockers and sway bar disconnect from the factory switches, at any speed, in any transfer case range. It uses its own dedicated sway bar disconnect motor. The normal price for a “Full SmartBar Bypass" is $699 - This week only, a standard Full SmartBar Bypass is only $599! Works on all 2006-2018 Power Wagons.
Both of these systems are completely plug and play and don’t require cutting or splicing any factory wires. I custom build each system by hand, from scratch, one at a time and it comes with a 2 year warranty covering defects in materials or workmanship. Get your order in early to secure this sale price, supplies are limited (offer expires 5/31/25). Just send me an email to place your order: AbelComponents@yahoo.com
Abel Components Memorial Day Sale!
Re: Abel Components Memorial Day Sale!
