Abel Components Nanny Kill Switch® - $79
Retired BLM Rig products
Weaver52
Re: Abel Components Nanny Kill Switch® - $79
Post by Weaver52 » Wed Jan 25, 2023 9:47 pm
Need to
Order one for my 2018 Cummins please let me know what I need to do
TEAMRAMROD
Post by TEAMRAMROD » Sun Apr 30, 2023 5:16 pm
I have a 2015 Ram 2500 cummins, how do I purchase a nanny killswitch?
OHVRESQ18
Model Year: 2019
Post by OHVRESQ18 » Thu Sep 28, 2023 3:05 pm
PM sent
Jiminruskin
Model Year: 2019
Post by Jiminruskin » Sat Oct 21, 2023 3:51 pm
PM Sent
Jiminruskin
Model Year: 2019
Post by Jiminruskin » Thu Oct 26, 2023 9:12 am
Thank You!
TommyG
Post by TommyG » Thu Nov 21, 2024 11:19 am
PM sent. Need one for a 2021 Power Wagon.
TommyG
Post by TommyG » Mon Nov 25, 2024 7:48 am
Retired BLM Rig wrote:
Sun Nov 24, 2024 5:16 pm
PM sent. Need on for a 2021 Power Wagon.
Sent you an email with info. :patriot:
Thank you. I thought I sent a reply over the weekend but emails are not sending from my phone for some reason. I tried again from the laptop this morning. Please let me know if it does not come through.
TommyG
Post by TommyG » Wed Feb 26, 2025 8:53 am
Finally got this installed. Ended up adding a Switch Pros 9100 in the truck and was able to order the kill switch pre-wired to work with the switch panel. Got everything buttoned up this weekend while it was a little warmer out.
Instructions were detailed and easy to follow. Installation itself is very simple. Works as advertised and make a huge difference when you need to be in control rather than the ECM. One of my favorite upgrades to the truck.
Post by adeluca73 » Wed Feb 26, 2025 2:20 pm
I did the same a few weekends ago on my 2024 PW. I connected to my Garmin Power Switch which is BT to my phone & visible on my 12” Uconnect via Apple Carplay. Works great.
    - Strip LEDs
  • Garmin Power Switch Powering:
Post by OffroadTreks » Thu Apr 17, 2025 6:19 pm
Hey Abel in your original setup you had Red Power and then a Brown and Yellow wire.
Can you remember or remind me of the original wiring config for the Yellow and Brown wire?
Post by OffroadTreks » Thu Apr 17, 2025 6:25 pm
Holy crap I forgot I made a video and literally said what the wires were in the video!!! My brain dead self recently decided to redo all my wiring without labeling what I was unhooking. Whomp Whomp.
https://youtu.be/18zhJp9jbKE?si=q0QAQ4tUKxl15bjd&t=548
God I was fat, that's embarrassing. Life is better when you get in shape fellas. Don't be like old me.
Post by OffroadTreks » Fri Apr 18, 2025 1:01 am
I got it hooked back up. LOL
I got into a sidequest when I was just going to fix one thing and ended up re-wiring everything on the truck for 3 days. LOL
Post by Retired BLM Rig » Wed Apr 23, 2025 9:21 pm
Well a new development has come up on the 5th gen. trucks. Ram has issued a recall to reprogram the ABS module. Once the reprogramming is updated, it renders the throttle nanny override portion of the NKS useless. I’ve had a couple customers contact me and confirm that their Nanny Kill Switch was working normally before the recall and then afterwards the throttle nanny came back, inhibiting wheel spin, even if the NKS was turned on.
At this point the only option that 5th gen. owners have of turning off the Traction Control to allow wheel spin, is to do a long 5 second press/hold on the factory TC switch, until you hear a chime. The only problem with this is that the Traction Control is never really fully turned off, it’s always lingering in the background and if you exceed a certain speed or yaw rate, it kicks back in again automatically and inhibits throttle response.
The ABS portion of the NKS still works, so if your main concern is being able to lock up your wheels and skid to a stop on any surface, it will still serve that purpose.
Post by adeluca73 » Tue May 13, 2025 11:11 am
I still love it! Love the virtual switch option on my 12” infotainment screen — I’ll just slow roll , maybe never, the recall!
    - Strip LEDs
