Abel Components Full SmartBar Bypass® $699
Retired BLM Rig products
Post by Retired BLM Rig » Sun Feb 07, 2021 3:26 am
Abel Components Full SmartBar Bypass® - $699
The Full SmartBar Bypass combines the Locker Bypass and the Sway Bar Bypass into one component that still uses all the factory switches and is completely plug and play with no cutting or splicing of any factory wires. It gives you full control of the lockers and disconnecting sway bar, at any speed, in any transfer case range. It works on 2006-2018 Power Wagons (NOTE: This does not work on 2005 or 2019+ trucks). Installation takes 2-3 hours depending on your skill level and specific configuration.
For 2005 the standard Locker Bypass and Sway Bar Bypass will work to give you full control. 2005 is the only year that came with a separate factory sway bar switch and I've tried multiple times to make it work, only to end in frustration.
On 2019+ trucks these systems are controlled on the high speed CAN-Bus data stream and not with traditional switches. The only way to modify these systems on a 2019+ truck is to change the software (I'm not a software guy) or hardwire them with dedicated switches. The standard Abel Components Sway Bar Bypass works perfectly on 2019+ trucks. I also offer hardwired locker harnesses if you want to use your own switches.
As all of these trucks age and these systems fail and parts become obsolete, this is a viable option to restore proper function using the factory switches. Even if your locker/sway bar system is completely dead with no lights on the factory switch, I can build a kit that will bring it back to life for less than half the cost of a new Final Drive Control Module/SmartBar.
To order any of the components that I offer here, contact me at: AbelComponents@yahoo.com :patriot:
A portion of the sale of these products is donated to Power Wagon Registry each month. :winchmob:
Last edited by Retired BLM Rig on Mon Sep 06, 2021 11:58 am, edited 5 times in total.
Re: Abel Components Full SmartBar Bypass® $699
Post by PWJouster » Mon Feb 08, 2021 9:43 am
Abel just took 4th gens to the moon.
LockedandLoaded
Post by LockedandLoaded » Mon Feb 15, 2021 11:09 am
Just got mine installed. This is how the truck should have been from the factory! :cheers:
ScubaSteve
Post by ScubaSteve » Sat Jul 31, 2021 8:03 pm
I'm assuming that there is not much that carries over from the Locker Bypass kit you have? If I were to upgrade to this setup, the only thing I would be able to retain would be the run to the rear locker, correct? Full control over the sway bar is looking very tempting.
Post by Retired BLM Rig » Mon Aug 02, 2021 2:05 am
I was recently able to find a supply source for the connector that plugs into the back of the factory dash switch. I have a new prototype that's being installed and tested soon on a 4th gen. This new setup would eliminate the indicator light issues caused by wiring harness changes that occurred on the 4th gens. I'll send you an email to discuss some possible options for upgrading to this new system.
ThomasKeife
Post by ThomasKeife » Wed Sep 08, 2021 4:11 pm
I am currently dealing with my Ram dealer having my stock 2018 power wagon in and out of shop for four weeks now. It all started when the lights on the control knob for the front and rear lockers started flashing like they where trying to engage, while driving with the knob in off position in 2 wheel drive. Technician said a code was active: "C144E- front differential position sensor performance" so the nightmare began. The shop at dealership where I purchased my power wagon began trouble shooting. They started by servicing both axels and attempting to clean out any metal fragments from lockers magnetics. Then they replaced the front locker actuator claiming it had shorted out. Then they told me that the shorting out of the actuator sent a surge of power back to the smart bars control module damaging it. So I said ok replace the control module but the technician told me that they couldn't just replace the module they had to replace the entire sway bar and electronic disconnect assembly as the module was only available connected to the assembly. Feeling I had no other option at the time I agreed and allowed them to replace the smart bar sway bar entire assembly including the new control module $2900. Mind you the repair cost is climbing I'm well over $3,500 now and the lights are still flashing on the knob that controls the lockers. The electronic sway bar disconnect and the lockers still won't function for more than a few seconds before the truck disables them again. The lights still are flashing regardless of position of switch/knob. Now the dealership says they have to consult Ram engineering as everything they have done according to their procedures should have corrected the problem and they are stumped meanwhile I'm without my truck. This all started about 2,000 miles after the trucks warranty had expired. I am curious about this new full smart bar bypass kit including locker bypass that connects to the stock switch to bar and knob to lockers with out warning light and codes. Could this kit possibly fix my problem? Being able to use my sway bar disconnect and lockers at my discretion regardless of drivetrain position or vehicle speed sounds amazing and is how all my older 4x4s where built to work. I don't like having a computer control all my off-road components. I can do basic wiring with with good instructions but I am no technician. Please help!?
Bigbrokenzj
Re: Abel Components Full SmartBar Bypass[emoji2400] $699
Post by Bigbrokenzj » Wed Sep 08, 2021 10:11 pm
While I can’t speak to the smart bar bypass, I installed the locker bypass and nanny kill last week. The components are super well made and Abel components is a fantastic to deal with. Everything worked perfect out of the package. Well worth it.
2018 PW
Post by Retired BLM Rig » Tue Sep 14, 2021 12:48 am
As you know I already responded to your email. For the benefit of others reading this thread: Yes this bypass system would solve your problem and give you full control of these critical Power Wagon accessories. It takes basic skills and 2-3 hours to install.
Mountaingoat1
Post by Mountaingoat1 » Fri Sep 17, 2021 11:56 pm
Will this full smart bar bypass work on a 2021 or is that where you said it’s a software issue? I just traded my 2018 in on a 21’ and I am missing the locker bypass already! It worked flawlessly.
Post by Retired BLM Rig » Sat Sep 18, 2021 2:05 am
The 2021 stock allows the rear locker to work in 2H, 4H and 4L. The front locker only works in 4L. You have to be traveling less than 3 MPH to engage them. Once it's locked, you're good to go. The only way to bypass the new trucks is to hardwire them, because they're controlled on high speed data stream.
