4th Gen Locker Bypass Instructions
Retired BLM Rig products
Post by Retired BLM Rig » Sun Jan 05, 2020 3:16 am
The Installation instructions can get lost or misplaced, so I thought it would be good to post them here so everyone can access them. The only problem is that it's a PDF file and this forum doesn't support the PDF format, so I've converted each page to its own JPEG image to make this work. They do get a little grainy after converting and downsizing, so if you want better quality, shoot me an email.
For some reason I can't delete the old instruction attachment pictures at the bottom of this post, so please disregard them. The old system mounted in the engine compartment, the new system mounts the control box under the dashboard and passes the harness through the clutch master cylinder block off plate hole.
Enjoy! :patriot:
Last edited by Retired BLM Rig on Sat Jan 01, 2022 5:52 pm, edited 3 times in total.
Oilbrnr
Re: 4th Gen Locker Bypass Instuctions
Post by Oilbrnr » Sun Jan 05, 2020 9:39 am
Very easy install. It's nice to decouple the bar at will.
'16 with '17 FWC
Re: 4th Gen Locker Bypass Instructions
Post by olyelr » Mon Jan 13, 2020 10:35 pm
Great idea to post this up :rockon:
Great job with this stuff! So professional looking!
