Towing 8K lb trailer, Air Bags w/Cradles or WDH?
Which setup would you/do you use?
Weight Distribution Hitch (WDH) Only
5
33%
Cradles and Airlift Airbags w/Internal Jounce Bumper
0
No votes
All of the above
10
67%
Total votes: 15
Re: Towing 8K lb trailer, Air Bags w/Cradles or WDH?
Post by Mule007 » Sun Mar 28, 2021 9:24 am
I was in commercial construction & used to tow a concrete form trailer before I retired. Heavier loads. Just never changed after retirement. Don’t use them if off road other than gravel mainlines so never felt the need.
pdavey
Post by pdavey » Wed Mar 31, 2021 3:10 pm
Mule007 wrote:I was in commercial construction & used to tow a concrete form trailer before I retired. Heavier loads. Just never changed after retirement. Don’t use them if off road other than gravel mainlines so never felt the need.
Sent from my SM-G998U using Tapatalk
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
