Boogie bump stops AND Airbags
Posted: Thu Mar 09, 2017 11:20 pm
by TankerZak
So I'm putting on the Air Lift 5000 Ultimates with the internal jounce and the Daystar cradles. That has to happen because of my trailer weight (removing Timbrens). So that decision is a lock and its already in my garage.
I was reading about the boogie bump stop replacements and they sounded interesting BUT i could only do the front. Any point in even doing that if i can't do the rears also? Would the airbags balance it out some or pointless mod?
Re: Boogie bump stops AND Airbags
Posted: Thu Mar 09, 2017 11:38 pm
by Colibri
Front bumps see a lot more action than the rears because of the nose heavy nature of our trucks. Get the boogies up front and install your bags out back and you should be good to go unless you chase in Baja
Posted: Fri Mar 10, 2017 11:34 am
by Low_Sky
Agreed. Worth it even if you can only do the fronts. (From a future boogie bump owner that is tired of contacting his front bump stops).
Posted: Fri Mar 10, 2017 12:16 pm
by OffroadTreks
Where are you guys getting them? I only found them for up to 2012 2500's on CJC...
Posted: Fri Mar 10, 2017 12:38 pm
by DamageWagon
Buy straight from Don
Posted: Fri Mar 10, 2017 1:05 pm
MikeKey wrote:Where are you guys getting them? I only found them for up to 2012 2500's on CJC...
Yea Don has them listed on his website. Can buy them with a full kit or can purchase separately.
https://www.thurenfabrication.com/produ ... stops.html
Posted: Sat Mar 11, 2017 1:02 am
by TankerZak
I take it we need the 1-3 inch lift set? With appropriate front mounting bracket?
Posted: Sat Mar 11, 2017 9:41 am
TankerZak wrote:I take it we need the 1-3 inch lift set? With appropriate front mounting bracket?
Yes and yes. Well, 0-3" lift.
Posted: Sat Mar 11, 2017 9:42 am
Not a power wagon and not a new ram, but this is the jist of it
https://m.youtube.com/watch?v=w0U-mqmCk-8
Posted: Sat Mar 11, 2017 11:05 am
by OffroadTreks
Thanks that video was perfect.
Sadly everything on this truck is just as pricey as buying stuff for my Corvette. I thought it would have been cheaper.
Posted: Sat Mar 11, 2017 2:50 pm
Cant leave the vette well enough alone either, eh
Posted: Sat Mar 11, 2017 6:02 pm
by OffroadTreks
olyelr wrote:Cant leave the vette well enough alone either, eh
I have to many things to spend money on. I'm just trying to spend it all before my girls are teenagers.
Posted: Sun Mar 12, 2017 9:48 am
