TankerZak wrote: ↑Sat Oct 20, 2018 7:20 amI'd bet money it's your fitting. Toss some water on the fitting area and look for bubbles. Same thing happened to me. They shouldn't loose air except for ambient temp adjustment which can be pretty significant because of small volume size.olyelr wrote:Yea I took the spacer out per Tankerzak’s recommendation and everything still works great. And I gained back the inch of compression, which was a noticeable loss.
Abnormal wear? Pffffff, guess I would have to look them over because I never really have. I will say, the trip up to the UP and back last week, when I got home and went to let the air out of the bags, the drivers side was already empty. So i may have a slow leak at a fitting.
Forgot to add in where the leak was. It was the valve stem core. Tightened it up a bit and all is good now.
