Power Tank Inflator
Posted: Sat Feb 15, 2020 7:32 pm
Putting the pieces together to put on board air on the truck later this year and this just showed up. Used it out in the shop a few times now and man is it nice. Clip the chuck on the valve stem and step back with the gauge in your hand.
It has a nice high flow and there is a valve to let some air off if you over inflate a little. Best of all you don't have to crouch next to the tire for the time it takes to air back up. I picked up the little padded bag that goes with it and am going to keep it in the gear that stays in the truck all the time.
https://powertank.com/collections/tire- ... e-inflator
