Thinking maybe I should do a pkg deal.
Brand new factory rock rails
Hellwig Load Pro 35, 4-leaf adjustable helper springs, just removed. Will clean up & paint if needed
8 new Mopar oil filters, in box's
Brand new Transfer Case Position Sensor, in box
Carli old style new track bar bushing & brand new threaded rod end, in plastic pkgs
Factory upper & lower control arms, not bent, in box
2 new atv CV boots for the G-56 manual transmission shifter boot, in box
new NAPA sway bar ends, in box
K & N washable, reusable air filter, in box, just cleaned & recharged.
Stock rear diff cover
P Crainium full rear diff spider guard
Stock front brake lines
Custom made tailgate weight transfer platform---so when you haul heavy atv's & such, the weight is transferred directly to the 2" receiver & won't bend your tailgate plus no more worries of cables failing after they corrode
And other stuff i forgot
+ brand new in box fog light set
+ brand new in box rear driveshaft u-joints
Will remove the 270 amp alt if someone is seriously interested in a pkg deal for all.
I think it is fairly safe to say that these are probably the last brand new set of 3rd gen rock rails, complete w/all hardware, left in existence.
