NO LONGER AVAILABLE: 3rd - Early 4th Gen Faux Low Locker Bypass
Posted: Wed May 31, 2017 12:37 am
by Retired BLM Rig
THIS ITEM IS NO LONGER AVAILABLE. IF YOU'RE LOOKING FOR A LOCKER BYPASS, CLICK HERE.
I had some extra supplies left over after building a plug and play locker bypass for my truck. This is a resistor and toggle switch type setup and does not require cutting or splicing any factory wires. If your truck has the New Process #271 transfer case, this will work. Fits 2005 - early 2012 PW. I'll include the toggle switch, unless you'd rather find your own to match other switches in your truck. It would need to be a single pole double throw (SPDT) "On-On" switch (no center off position). Asking $75 check or PayPal. It will come with instructions and I'll pay the shipping. NOTE: This will not fix a faulty locker problem on your truck, it just gives you more options as to when you can use your lockers. Note: This will not work if your truck has a Borg Warner transfer case.
Re: For Sale: 3rd - Early 4th Gen Locker Bypass
Posted: Wed May 31, 2017 11:00 am
by cruz
PM sent , I'll take it.
Posted: Sun Jun 04, 2017 2:03 pm
by Retired BLM Rig
I still have one more set of connectors that I could use to build another bypass if anyone else is interested. I only had one toggle switch however, so you would need to source your own.
Posted: Tue Jun 06, 2017 10:27 pm
by Retired BLM Rig
Sold.
Re: For Sale: 3rd - Early 4th Gen Faux Low Locker Bypass
Posted: Mon Jul 09, 2018 3:04 am
by Retired BLM Rig
I have another faux low locker bypass available for sale. This is the unit that I built to experiment with on Olyelr's truck. After determining that it doesn't play well with the CAD front axle on 14+ trucks, I reconfigured it for use on the 3rd gen and early 4th gen trucks. If your truck has the New Process #271 transfer case used from 2005 thru early 2012 this will work for you. This one is set up with wireless controls to use either the included key fob or you can program one of your Homelink buttons to turn it on and off, so you don't need to think about where to mount a switch or run wires into the cab.
It's easy to install: One wire in the fuse box, one wire to ground and two plug-ins at the transfer case. Comes complete with illustrated instructions. It's completely plug and play, no cutting or splicing of wires required. Lots of 3rd gen guys on this forum have the toggle switch version of this bypass installed on their trucks, including me. This is the only style locker bypass that was ever offered for the 3rd gen. It allows you to disconnect your sway bar at anytime under 18 MPH and lock your lockers in any transfer case position (2WD, 4HI, 4LO).
I'm asking $140 for this one because it's the wireless Homelink version and I just want to recoup my expenses for parts and supplies. I'll cover the shipping cost as well. Check, money order or PayPal accepted. FYI: There is someone else on the web selling the toggle switch version of this bypass for $200.
- This picture was taken before being reconfigured. The fuse is different and the resistor is embedded in the harness to protect it from the elements.
Posted: Mon Jul 09, 2018 9:09 am
by PWJouster
i would take that setup on a sway bar disconnect for double that price.
really wish this setup would work on a 2018, but this should sell quick!
Posted: Wed Aug 01, 2018 1:00 am
by Retired BLM Rig
Lowering the price on this to $99 and I'll still pay for the shipping.
Posted: Tue Sep 11, 2018 11:52 pm
by Jrlinne
Hi I’m really new to all of this. As I understand this tricks your transfer case into thinking it’s in 4 low? If so does it change into 4 low mapping for the engine? Sorry if that’s worded wrong but I am very interested.
Posted: Fri Sep 21, 2018 1:31 pm
by Low_Sky
Jrlinne wrote:Hi I’m really new to all of this. As I understand this tricks your transfer case into thinking it’s in 4 low? If so does it change into 4 low mapping for the engine? Sorry if that’s worded wrong but I am very interested.
It tricks the truck into thinking that the T-case is in 4LO, permitting the things you are allowed to do in 4LO while you are in fact in a different T-case gear. You get lockers, swaybar, and 4LO engine mapping in 2HI, 4HI or 4LO.
Posted: Fri Sep 21, 2018 3:29 pm
by Retired BLM Rig
Low_Sky wrote: ↑Fri Sep 21, 2018 1:31 pm
What he said.
Re: NO LONGER AVAILABLE: 3rd - Early 4th Gen Faux Low Locker Bypass
Posted: Sat Dec 08, 2018 8:04 pm
by Retired BLM Rig
