Heater problems
Heater problems
Hi, I have a 2015 PW. It has the dual climate w it h the 8.4 Uconnect. Problem I’m having is it’s not getting heat to the driver side however it is heating the passenger side. Any ideas ? I know I have read some stuff about an actuator for a blend door but what I could find was mostly on older models. Thanks for the help !
Heater problems
Heater problems
Hi
I have a 2015 PW. It has the dual climate with the 8.4 Uconnect. Problem I’m having is I’m getting heat to the passenger side however I have no heat on the driver side. It just blows cold air. Any ideas? I have read some stuff about an actuator for a blend door but what I could find mostly pertained to older trucks. Thanks for the help!
JD
JD
Heater problems
Hi
JD
JD
