OBD Code Readers
altaguy
OBD Code Readers
Post by altaguy » Sun Dec 08, 2019 1:35 pm
I have noticed a lot of people say that you need a very expensive scanner or have to go to the dealer to read locker codes and such. I bought an Autel MD802 full system code reader for 220 CDN off Ebay (brand new, never used) and found that it reads those "C" codes. I am sure that any of their full system scanners will work. I wish I had it when I was bothering Retired BLM Rig about the 05 wagon I was fixing up to sell!!! (Thank you again David).
Anyway, just thought I would throw this out there and hopefully it helps some of you.
Shayne
Re: OBD Code Readers
Post by TankerZak » Sun Dec 08, 2019 4:22 pm
I just use a Bluetooth OBDII with a few apps on my phone to read my codes and program the truck...
altaguy
Post by altaguy » Mon Dec 09, 2019 8:35 am
Does that read locker codes? They start with a C. Reading the codes to troubleshoot locker issues is handy. I plugged mine into my 2012 with myoung's bypass and it showed the codes created using the bypass.
Post by TankerZak » Mon Dec 09, 2019 11:39 am
No idea. I'll check when I install my locker bypass. But I'm sure it reads everything as it can modify everything...
