KC Lights intermittent on while switch off
Posted: Mon Dec 02, 2019 11:06 am
Just experienced a new problem on the way into work this morning.
We've had a bit of freezing rain/sleet/snow overnight, so there is a bit of moisture. Anyway, driving in this morning I noticed reflection of my lights flashing on and off in the tailgate of the truck in front of me.
At first I was thinking my automatic headlights because it is overcast. I then determined it was my KC spots (halogen) in the middle of my lightbar, which narrows it to 1 circuit. The 2 spreads on the outside are on their own circuit w/ their own relay and switch, and appear not to be affected.
So, those 2 lights are on their own circuit with a switch in the cab. They are wired in the configuration to only be connected into the battery (stand alone). Not connected into high beam circuit.
I guess I know my answer, but I will pose it here. Do you guys just think it is short somewhere. i.e. common wire is making contact somewhere, or water is somehow bridging to complete a circuit?
I've used dielectric grease on all connectors and relays. I only installed these last year. Could a wire be worn through already?
For now I disconnected the connectors for those 2 lights so my battery doesn't die while I'm at work.
Any positive advice is welcomed.
