Do whatever you have to when building these. There's a lot of us who appreciate your hardwork!myoung84 wrote:Everything has been ordered! I made a last minute change to the way the harnesses will enter the box. I had planned on using a cable gland but thought it was worth the extra money to use a panel mount Molex connector. This will make building them and installation much easier and provide better water tightness.
- BigRed2007
30. Bigred2007 - 3rd Genbstefanic wrote:Thanks for the good work!
1. myoung84 - 2012
2. 04Ram2500Hemi - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
6. Wingerak92 2012 (next year, need tires first)
7. TwinStick-----3rd Gen 2008 w/G56 (LATER)
8. Hemi46. 05 gen 3 (later)
9.gtomike60-2012
10.glidehm
11. ScottWagon1-later
12. Mexican Import - 2013
13. MSCH2112 - 2013
14. BMWS52-2011
15. Mopar Bob (2012) - Later
16. Juday (2012) - Later
17. Nrooney21 (2012)
18. RustyPW '08 3G (when you get the 3G figured out)
19. Jeep_boy02 (2010)
20. Rgory (3rd Gen) When you get it figured out
21. Bajaben48. (later....tax return )
22. Iamahemi (2012) later
23. BigMike 2009
24. GunniPWguy (2005) worthy mod someday
25. bigblackdodge (2010)
26. blindsquirrel33 (2011)
27. StubiePW 2012 (later)
28. bstefanic-3g 2006
Sent from my ADR6410LVW using Tapatalk
Flame Red 07 PW - BIG RED
KE0BZG
WQUY939
KE0BZG
WQUY939
Please add me to the list.
warroad 2013
warroad 2013
First shipment came in yesterday. 1600 pins and 260 connectors! I'm expecting 2500' of wire today and 25 boxes and 1500' of wire loom tomorrow. This weekend I'll pull the kit from my truck, take down all the measurements, and start laying some harnesses.
I'm still waiting on the relays from China which will hopefully be here in the next couple weeks. I hope to have a majority of the harnesses done before that point and be able to start shipping out early December. I don't know how long it will take to build each harness and wire up each box yet. There's about 50 pins to be crimped for each kit! I'm glad I bought some nice ratchet crimpers, they make it pretty easy and turn out oem quality crimps.
AWESOME!!!! I wish I had the $$$ right now, I'd be ordering one from you!!!
I'm building 25 this first run. I'm sure I'll be able to take care of you when the time comes.
I'll also be digging into the 3rd gens before too long. Everything in the box should work for 3rd gens but there will be a slightly different harness to interface with the oem knob. I'll need some help once that times comes since I don't have a test vehicle... I wish one of you were near Tulsa!
If I was closer. You could use my 3G PW. Since I'm not driving anything right now. Waiting on the doctor to give me the ok.
- jeep_boy02
There is a 3G in Joplin... probably not on here but I have seen him on the road. If I catch him I will have a chat about the site and the fact you could use a test bed if you'd like.
I've seen two 3rd gens in the area but they are both stock and I doubt they would be interested. The probably don't even use the lockers...
This is what 1500' of wire loom looks like! I was a little surprised to see this many boxes on my porch today!
that's alot of pins, connectors, and wire!
mike
mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Gooseneck
2016 Volvo XC90
Whatever you do…. Don't drop that box!!!myoung84 wrote:First shipment came in yesterday. 1600 pins and 260 connectors! I'm expecting 2500' of wire today and 25 boxes and 1500' of wire loom tomorrow. This weekend I'll pull the kit from my truck, take down all the measurements, and start laying some harnesses.
I know! That's going to be a bad day when I dump the whole box!
can someone add me to the third gen list? thanks
As my wife and daughter tells me all the time "You're a big dumb rock" I would have already dumped that box over as I find myself doing it all the time with my tackle box while sitting on the bank of the pond in about 2' of grassmyoung84 wrote:I know! That's going to be a bad day when I dump the whole box!
Great work on this upgrade, I need to think about this now.
So let see, I have the locker by-pass from five years ago still on the truck which I am having no issues with, and because of my rear locker going bad I also installed toggle switches to both front and rear lockers, so at least I have lockers in the front now. What is another upgrade going to do... Right? At some point I need to take a step back and take one of them off and just keep one as I think with all the upgrades currently on "OX" I might be causing some of my own issues which made the rear locker go bad in the first place
Power Wagon Registry #47
- Thuren steering upgrade
"The" Wifes Car
"Faith" 2014 Charger RT Max
My Toy
"VISCO" 2013 196CC Tidewater
"The" Wifes Car
My Toy
I took mine out today, cut the harnesses to the proper lengths, took measurements, wrapped them in wire loom, mounted the plug in the box, and cleaned up the wiring inside the box. I still need to remove the harness that goes to the rear axle and wrap it in some loom and take my final measurements. Here's some pics of what the final kits will look like. The T harness on will look a little cleaner on the rest of the harnesses....
- Stickman
I'm new to the site but have been visiting here and the forums over on DodgeTalk and RamForum for awhile looking for ideas and seeing what everyone is doing to their PWs to make them the ultimate on/off road truck that looks as good as it performs. I'd deff. like to be on the list for one of these harness's. My lockers and sway bar have worked fine so far thankfully but I can deff. see the advantages to being able to use them in 4hi or 2wd. Somehow I managed to luck out and caught this thread right as you got everything buttoned up and started making them to ship. Thanks for all the hard work myoung84!
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
??30. Bigred2007 - 3rd Gen
31. Stickman (2012)
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
31. Stickman (2012)
I give you credit for the craftsmanship! No doubt!
Great job. Can't wait till you get them complete looking forward to testing it out myself. Thanks for all your hard work.myoung84 wrote:I took mine out today, cut the harnesses to the proper lengths, took measurements, wrapped them in wire loom, mounted the plug in the box, and cleaned up the wiring inside the box. I still need to remove the harness that goes to the rear axle and wrap it in some loom and take my final measurements. Here's some pics of what the final kits will look like. The T harness on will look a little cleaner on the rest of the harnesses....
Nice job!
- JBM Power Wagon
That is a nicely put together setup, very professional!!!
Thanks guys!
