Bring it on! I'll be ready! I hope...Mexican Import wrote:You are gonna have a frenzy on your hands once you get these to market. I know I will probably harass you a bit... sorry in advance.
myoung84 wrote:
1. myoung84 - 2012
2. BlkWgn 2006
3.
4.
5.
6.
7.
3.myoung84 wrote:My relay board is not going to work, I didn't read the specs close enough on the input power and it requires 24V. After adjusting the pots, the LEDs function perfectly but there's not enough voltage to trip the relays. However, I have found a better alternative at a lower cost, so I'm considering it a win! I ordered the new boards (one for each axle) and they should be here in a couple days. Bad part is getting them from a US supplier makes them a lot more expensive but I went ahead and bought two of them so I could finish testing. Once testing is done I'll have to order these from China...
If all goes well, I'm going to be able to sell these for a lot less than I was expecting. Buying everything in bulk helps a ton. They will a good bit less than $300. Since I'm about 97% confident that everything will work like I planned, I'd like to start a list of who will be ready to purchase as soon as these are done. I hope to have most if not all of them out the door by the end of the year. If you wouldn't mind, copy and past the list below and add your username and year of your truck. This will also help in determining the final price. I'm going to be on the hook for a lot of parts so I want to have a good list of who will be able to buy right away.
1. myoung84 - 2012
2.
1. myoung84 - 2012
2.
There's no telling on the 2015. Ram could see what I'm doing and change everything. Lol. Since it will still be a 4th gen, I imagine it would work. 2016 should be the year of the 1500 5th gen and 2017 will be the HD 5th gen, if they follow suit from previous gens.MSCH2112 wrote:do you have a summary of the installation process you think will be required for this project? i'm just not an electrical guru so i'ld like to know what i'm up against prior to ordering.
thanks,
mike
ps. try to make it adaptable for the 2015 PW (10th anniversary edition) i'm going to buy so i can transfer it!hmmm...so much for the warranty but if i'm buying new in 2015 who cares!
It's the same exact relay board. I just found a seller in the US that had a few available for a quick delivery.TrueBlue13PW wrote:3.myoung84 wrote:My relay board is not going to work, I didn't read the specs close enough on the input power and it requires 24V. After adjusting the pots, the LEDs function perfectly but there's not enough voltage to trip the relays. However, I have found a better alternative at a lower cost, so I'm considering it a win! I ordered the new boards (one for each axle) and they should be here in a couple days. Bad part is getting them from a US supplier makes them a lot more expensive but I went ahead and bought two of them so I could finish testing. Once testing is done I'll have to order these from China...
1. myoung84 - 2012
2.
4.TrueBlue13PW
I would rather have the USA made relay boards. That may just be me but if giving the choice I'd pay extra to have all USA made components.
Well then....wingerak92 wrote:Not throwing my name on the list yet….. Have other financial priorities… but just so he isn't forgotten, the list would be:
1. myoung84 - 2012
2. 04Ram2500Hemi - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
8. Hemi46. 05 gen 3 (later)TwinStick wrote:1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
6. Wingerak92 2012 (next year, need tires first)
7. TwinStick-----3rd Gen 2008 w/G56 (LATER)
10.glidehmgtomike60 wrote:8. Hemi46. 05 gen 3 (later)TwinStick wrote:1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
11. ScottWagon1-laterglidehm wrote:10.glidehmgtomike60 wrote:8. Hemi46. 05 gen 3 (later)TwinStick wrote:1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
