One headlamp not working.
Ak68w
Post by Ak68w » Mon Jul 20, 2020 10:29 pm
2012 pw. My passenger side headlight is inop. Low Beam, high beam nothing. Running light works. I’ve changed bulbs, cleaned contacts, and after doing this twice, it worked intermittently a couple of times. I’m at a loss.
SeppW
Re: One headlamp not working.
Post by SeppW » Tue Jul 21, 2020 7:49 pm
Running OE bulbs (halogen I assume)? Any hotter and wire harness may have melted somewhere and is shorting out. How is the socket assembly? Check the whole harness for short to ground, major PITA though. Checked fuse and relay?
Ak68w
Post by Ak68w » Mon Jul 27, 2020 8:24 pm
Factory bulbs. Wiring harness looks good. I wasn’t aware there was a fuse or relay? I looked on the fuse box I. The engine compartment and couldn’t find one. Where is it located?
SeppW
Post by SeppW » Tue Jul 28, 2020 6:28 am
No fuse or relay, then could be the Total Integrated Power Module (TIPM). If it is, it is not not a cheap fix. You should be able to find the pin out on the Web and find the wire to the headlight and diagnose. The TIPM is not clear to me because under the PCM (or IPM) is where all the harnesses connect. I assume that is the TIPM.
If the dealer deals with it and it is the TIPM, you looking at least $1000.00 maybe more. Rebuilt TIPMS are abut 500 or so and can be replaced by you, but need to determine if the wiring is not the issue.
Ak68w
Post by Ak68w » Sat Aug 15, 2020 12:20 am
My god. This will absolutely be the last dodge I own.
phonegenius06
Post by phonegenius06 » Wed Aug 26, 2020 8:31 am
I had an issue with my 2011. Turned out to be the connector. Here is the link for the youtube I found that helped. Hopefully it helps.
https://www.youtube.com/results?search_ ... +headlight
2k5PW
Post by 2k5PW » Sun Nov 01, 2020 3:01 pm
If it's the TIPM, you can buy one on eBay for about $150. You can also send it in to a vendor on eBay to be refurbished for $150. Or if you have an LKQ local, it'll cost you $14.50. One from a 1500 5.7l gas will be exactly the same if you ensure that the model year is the same gen.
2005 SLT Power Wagon Mineral Grey#1197
Mostly stock with CAI and smoked lights
Milestar Patagonia 315/70/17 M/T
PSC Big Bore Steering Box
Synergy Adjustable Ball Joints
Synergy Steering Upgrade
Fox 2.0 Stabilizer
Bilstein 5100 Shocks
Energy Control Arm Bushings
Energy Sway Bar Bushings
Energy Track Bar Bushings
Yukon Axles
Spicer Life Axle Joints
Dayton Rear Progressive Springs
Let's go, Brandon!
KD0TFU
2k5PW
Post by 2k5PW » Mon Nov 02, 2020 8:14 pm
Two things I'd like to edit. 1) I'm looking at gen 3 TIPM's 2) the price at LKQ is $15.99 + $1.50 core.
But I'll still bet you could look up the complete rebuild in eBay for the same price of about $150. Surely better than paying $1k.
Fox 2.0 Stabilizer
Yukon Axles
Let's go, Brandon!
KD0TFU
