Locker bypass kit
Re: Locker bypass kit
Count me in for both for my 2017 PW
Interested in the new kit for the knob. 16 PW from The Great White North.
2016 Power Wagon SLT, 35"/12.5"/17" Toyo Open Country MT, 2 x Rigid 10" E-Series behind grille, 2 x Rigid Dually on Backrack, Smittybilt D-Ring on hitch, Uniden PRO520XL modded 25 watt CB w/300 watt 'Lil whip, and PA Horn speaker under hood, Mufflex 3.5" mandrel-bent Delete pipe, 84mm rocket launchers, Phased plasma rifle in the 40 watt range lasers and ejection seats coming soon!
FordyceCreekTrail
Where is the check out line for the Knob kit?
Bump for v2 update!
AlaskaTRX
- Model Year: 2017
New to the board, but interested in this for my ‘17 once it’s available. Any update on this?
I am desperate need of help on this issue/fix for my 2005 as well. I would like to be added to the list if the purchase of something comes available.
2005 Dodge Power Wagon
1977 Ford Bronco
1980 Toyota FJ40
1977 Ford Bronco
1980 Toyota FJ40
I am also looking into such a kit at the moment (or do myself)
As I understood so far, the problem comes from the electronic module inside the Smart bar, that controlls all the lockers and the sway bar.
Will this kit override this Smart bar control module if it fails for example? I want something 100% bullet proof as I will use the car in very remote areas. (sure, if the diff lock itself fails is another story)
Thnks for an input
Michel
Thnks for an input
Michel
2006 Dodge Power Wagon 2 door, planed to be used as an overland vehicle with a camper cabin
1972 Plymouth Road Runner 440-GTX, TX9 black with B5 blue interior and original airgrabber hood
Here’s a link to the current locker bypass, contact me if you’re interested: viewtopic.php?f=43&t=5876Blade wrote: ↑Mon May 06, 2019 11:44 amI am also looking into such a kit at the moment (or do myself)
Thnks for an input
Michel
