37x12.50R17 on stock 2023
Posted: Sun Nov 24, 2024 1:30 pm
by ldgregory
Got 37" Toyo Open Country R/T Trail meats put on my 2023 PW with no lift or leveling kit. Did a quick ride out to the desert with SilverWagon05 to get maximum stuff into the wheel well to check clearance and rubbing. There's a tiny bit of rubbing on the control arms and sway bar at full stuff, full lock, pushing into a hill. I can live with that as both are smooth and rounded parts and a little missing paint isn't gonna kill me. At full stuff and push, it is really close to the plastic wheel well lining, but it doesn't touch.
Only problem now is I need to come up with a mounting solution for my spare which doesn't take up the whole bed, is secure and doesn't require me to relocate my reverse camera or sensors.
Re: 37x12.50R17 on stock 2023
Posted: Sun Nov 24, 2024 9:11 pm
by RustyPW
You need to hit up Peter....can't think of his handle right now. He's done a lot to his '23.
Next thing you need is a Tazer.
Posted: Mon Nov 25, 2024 11:50 am
by Mule007
You’ve probably already checked Board Index Brakes, tires, wheels for37” spare tire carriers-several members have ideas there,,,OffRoadtreks, reloaded guy, Olyer(sp?). Tail gate, bed mounts, trailer hitch,,,,brands, discussions, pro’s & cons. Might be worth a look see,,,good luck,,,
Posted: Mon Nov 25, 2024 8:27 pm
by ldgregory
Thanks. I'm definitely going to do some digging in what other here are doing.
Posted: Mon Nov 25, 2024 8:31 pm
by ldgregory
I'll see if I can figure out who he is and look into what he's done. I actually went with the AEV Procal (was here when I got home from work today) to set the tire size. Didn't know about the Tazer, but the Procal worked great to get the speedo corrected. The hardest part was hooking up the jumper from the ODBII to the green Star connector.
Posted: Tue Nov 26, 2024 5:29 pm
by Retired BLM Rig
Here's his build thread: viewtopic.php?f=2&t=8123
Posted: Tue Nov 26, 2024 7:17 pm
by RustyPW
:rockon:
