Anyone still here?
Can anyone confirm the max tire size (for no rubbing) for a stock '13 Laramie PW? Currently running BFG 285-75-17 M/T's but hard to find anything in that size anymore and don't want the OE 285-70-17's. Anyone have experience with 35's and no rub on stock truck?
'13 PW Max Tire Size
2012 PW - gone
2005 PW - gone
'03 Kawasaki Prairie 650
2012 PW - gone
2005 PW - gone
Re: '13 PW Max Tire Size
Offroadtreks has a good article on biggest tires. Many members have had success w 35’s & min. Or no rub. https://www.youtube.com/c/offroadtreks, Hope this helps. Also lots of member feedback on this topic in this thread. Good luck! I run 35’s on my ‘05 w no rub but suspensions changed on the gen 4’s.
Thanks for the info! I had 35x12.5-17's on my 05 as well with no issues. But when I went to a '12 and then a '13, they rubbed a little. Haven't tried anything else but 285-75-17 since but it is soon time to be getting new ones.
2012 PW - gone
2005 PW - gone
2012 PW - gone
2005 PW - gone
- jeep_boy02
They rub at full lock on my 10. If you can metric out a 35x11.50 or even a 12 then it'd clear. I just used a 3/8" spacer.
need mods... too little time and money
