39s no lift
Payton12
39s no lift
Post by Payton12 » Mon Jan 24, 2022 6:52 pm
Trying to do 39s with stock suspension and the AEV Fender flares along with new Katala wheels. Is this possible? What other modifications would need to be made to avoid doing a lift?
Re: 39s no lift
Post by olyelr » Sat Aug 19, 2023 3:53 pm
Aev’s lift kit is really only 1.5” higher in the front than a stock power wagon, and they clear 40’s fine with the flares. So i would think its definitely doable. I would think pushing the axle forward 1.5” like aev does would be pretty crucial…unless you want to do a lot of trimming, which most likely would require messing up the flares.
Re: 39s no lift
Ooops, double post
