Issues after running 35s on my 2019 PW
Aldosari
Post by Aldosari » Fri Oct 29, 2021 6:31 pm
Hello,
I just changed my Power Wagon 2019 tires from the original tires to MT’s Baja ATZ p3 315 70R17 (35 12.5R17) with pressure of 40 psi on stock wheels. I have noticed that whenever speed goes over 70 KPH steering wheel start losing control a bit (like a space or gap in the steering wheel) and by 100 KPH I feel the truck shakes a bit.
I have done my homework before doing that and every article I have read confirms that there are no issues running 35s on stock power wagon.
My questions:
Is this normal and I need to do some modifications?
Do I need to upgrade my gear box?
Do I need to upgrade my steering stabilizer?
How to remove the under pressure sign from dashboard since it requires 60/65 front/rear?
Thank you.
