Wheel spacers on stock rims and 35's :))
Posted: Sun Jan 18, 2015 1:29 pm
by autogateman
Put a set of 1.5" billet wheel spacers on my 2012 and it looks great! I've always hated how far the tires stick inside the fender flares on these trucks, and this fixed it perfectly. It got my tires away from the control arms, and now they barely rub the lower plastic fender liner at full lock. They're model specific, with the metric studs and lugs. I had to trim about 1/8" off of my factory studs so the wheel wouldn't hit them, but not even to the threads.
Re: Wheel spacers on stock rims and 35's :))
Posted: Sun Jan 18, 2015 2:17 pm
by Stickman
Looks good. I'm wanting to get offset wheels that have just a tad of tire sticking out of the wheel wells, but then I don't think I'll ever be able to flex without the sound of crunching plastic and possibly metal.
Posted: Sun Jan 18, 2015 2:58 pm
by jeep_boy02
Plan on some other flares, rock dings and mud and what not will now be thrown all over the sides. Looks better tho. I just went to 35x12.5 all stock and rub a bit but already hate the fling they added so I can only imagine another 1.5"
Posted: Sun Jan 18, 2015 4:03 pm
by autogateman
I've had em on for two weeks now, they're not bad.
Posted: Sun Jan 18, 2015 4:13 pm
by Ducky's Dad
That will increase leverage and loads on front suspension and steering components, so plan to take off the spacers if you go back to the dealer for any work. They will probably use those to void parts of the warranty. Plan to replace some components earlier than normal. Your wheels are hub centric, so be sure the spacers are also hub centric.
Posted: Sun Jan 18, 2015 6:54 pm
by autogateman
Ducky's Dad wrote:That will increase leverage and loads on front suspension and steering components, so plan to take off the spacers if you go back to the dealer for any work. They will probably use those to void parts of the warranty. Plan to replace some components earlier than normal. Your wheels are hub centric, so be sure the spacers are also hub centric.
No warranty so not an issue
Any wheel where the lug sits in a concave seat is lug centric, even if it has a bore that is hub centric. So it doesn't matter. Meaning the lugs are going to center it anyway.
Posted: Sun Jan 18, 2015 9:28 pm
by Ducky's Dad
That's not true on my 3G. Yours may be different, but I doubt it. The concave lug seat is the secondary locator for the wheels on the hub. Without the hub fitting properly, your lug holes may get a bit egg-shaped over time if you use the truck hard. Your truck, your call.
Posted: Sun Jan 18, 2015 9:38 pm
by autogateman
Ok I appreciate your concrn
Posted: Mon Sep 07, 2015 11:05 pm
by SheepdogOutdoorsman
autogateman wrote:Put a set of 1.5" billet wheel spacers on my 2012 and it looks great! I've always hated how far the tires stick inside the fender flares on these trucks, and this fixed it perfectly. It got my tires away from the control arms, and now they barely rub the lower plastic fender liner at full lock. They're model specific, with the metric studs and lugs. I had to trim about 1/8" off of my factory studs so the wheel wouldn't hit them, but not even to the threads.
What size tires are you running? Have you fully articulated? Have your tires rubbed the fenders because they stick out further?
Posted: Tue Sep 08, 2015 4:28 pm
by autogateman
35 1250 17 federal Mt. If I cross a ditch at the exact right angle and stuff the tire it rubs the inner fender well. it can easily be pulled back but wasn't enough for me to worry about.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Posted: Tue Sep 08, 2015 5:08 pm
autogateman wrote:35 1250 17 federal Mt. If I cross a ditch at the exact right angle and stuff the tire it rubs the inner fender well. it can easily be pulled back but wasn't enough for me to worry about.
I wonder if I'd have any detrimental issues with my 37's and spacers ... Ugh ... I thought 37's were a no brainer reading what others posted, but I guess I should have just done 35's ...
Posted: Tue Sep 08, 2015 11:48 pm
by autogateman
spacers are no more harmful than wide wheels with big offset like all these mallcrawlers have, as long as you buy good ones.
Posted: Wed Sep 09, 2015 12:08 am
autogateman wrote:spacers are no more harmful than wide wheels with big offset like all these mallcrawlers have, as long as you buy good ones.
My concern is getting too wide and hitting the fenders
Posted: Wed Sep 09, 2015 2:46 am
by 06ryan27
Although I'm not disagreeing with what you did here (I probably would have done the same thing if i wanted to keep stock wheels) and I have run spacers on 2 different trucks (for front to rear axle width issues). I am disagreeing with you on this statement, a wider wheel more evenly distributes the stress, instead of moveing the whole tire out it really just moves the outer sidewall. unless you just have a stupid deep offset. But if our axles cant handle the wheel being out 1.5"s then i dont want them anyway.
Posted: Mon Jan 04, 2021 12:08 pm
by DevilDoc
Anyone have any pics of a stock rimed PW with 2” spacers and 35s.
Posted: Mon Jan 04, 2021 12:09 pm
by DevilDoc
Posted: Thu Jan 07, 2021 3:56 pm
by Bill2014
Wheel spacers are always a bad idea!
The people that use wheel spacers are the same ones that complain about their Unit Bearings failing...
And yes - post up pics of some of those Mall Crawlers
Posted: Fri Jan 08, 2021 2:46 am
by KevinABQ
I’m fairly sure this is a terrible idea, but has anyone used spacers to mount surplus hmmwv beadlock wheels to a PW? Did it work?
Posted: Sun Jan 10, 2021 5:27 pm
by EasyDoesIt
KevinABQ wrote: ↑Fri Jan 08, 2021 2:46 am
You have my attention.
Posted: Sun Jan 10, 2021 9:15 pm
by KevinABQ
EasyDoesIt wrote: ↑Sun Jan 10, 2021 5:27 pm
Mil surp hmmwv wheels are 16.5” with a viable bolt pattern. Iirc the hub size is a bit off, but fixable.
So there was a guy on youtube who was planning this big series of videos on how to fit hmmwv wheels on a 2500, and he started by saying, “ok, we’ll have to grind down the brake caliper a bit to make it fit. More next episode!”
There was no next episode, he posted a comment at the top saying it didn’t work and don’t try this. Apparently you will destroy the caliper before it fits. So the next thought would be spacers.
Which I know are generally a terrible idea, but I wondering....
Posted: Thu Jan 14, 2021 5:22 pm
by cb1987
Bill2014 wrote: ↑Thu Jan 07, 2021 3:56 pm
your better off not saying anything. then you can laugh when their wheel snaps off on the highway
