Quick question on tire pressures
Re: Quick question on tire pressures
I was lucky enough to have the tire tech not only ignore my instructions of 40/35psi with the new tires, but also ignore MFG spec of max 50psi, when he inflated mine to 65/80. How thoughtful of him. They even balanced three out of four wheels, too!
Most likely. Most people overload their trucks without realizing it. I know lots of guys with anti-WD hitches who didn't realize they have to adjust the hitch and their shit ain't set up right or even distributed.
Remeber, stupid is everywhere.
FWIW, I'm running 50psi front and 45psi rear with my 305/70/17 Toyo's and tire wear seems even. When I first put the Toyo's on I was running factory pressures and I had uneven tire wear (center of tread wearing faster than edge).
Mod's:
305/70/17 Toyo AT2 tires
Weathertech Floorliners
TSC Toolbox
Carli Diff Guard
Mod's:
TSC Toolbox
Carli Diff Guard
I'll have to get my tread depth gauge out and measure my tread, front and back, inside, center, and outside. I still have the original tires on the PW and have essentially always run 65 PSI min front and back. A little data will do us well here...
Tread depth readings from today:
Legend:
P = passenger side
D = driver side
R = rear
F = front
I = inside
C = center
O = outside
PRI = 16/32"
PRC = 16/32"
PRO = 15/32"
DRI = 15/32"
DRC = 16/32"
DRO = 15/32"
PFI = 15/32"
PFC = 15/32"
PFO = 15/32"
DFI = 15/32"
DFC = 15/32"
DFO = 15/32"
The tires have been rotated once so far (the dealer rotated them at the oil change last year). Rear tires (now on the front) wear evenly and faster than the front if your towing heavy. Front tires still seem to wear the edges faster even at 65 psi.
Legend:
P = passenger side
D = driver side
R = rear
F = front
I = inside
C = center
O = outside
PRI = 16/32"
PRC = 16/32"
PRO = 15/32"
DRI = 15/32"
DRC = 16/32"
DRO = 15/32"
PFI = 15/32"
PFC = 15/32"
PFO = 15/32"
DFI = 15/32"
DFC = 15/32"
DFO = 15/32"
I have to agree with Bill2014, as far as tire pressure goes for the stock tires. I have been running 62-65 up front and the damn things still look like they could use more air. It seems like I can get away with a bit less out back because I rarely am loaded up or towing anything. But they go right back up to max PSI when I hook the trailer up.
I have just over 17K miles on my tires now and they are wearing perfectly as far as contact patch goes. Tread depth seems to be a bit lower than I would have anticipated at this mileage, but then again I am just going by the eye-ball as I don't have a fancy depth gauge tool like Bill! They look pretty good yet until I look under the truck at the spare!
