37x12.50R17 on stock 2023
Only problem now is I need to come up with a mounting solution for my spare which doesn't take up the whole bed, is secure and doesn't require me to relocate my reverse camera or sensors.
2023 Power Wagon
Previous Truck
Previous Truck
Re: 37x12.50R17 on stock 2023
You need to hit up Peter....can't think of his handle right now. He's done a lot to his '23.
Next thing you need is a Tazer.
You’ve probably already checked Board Index Brakes, tires, wheels for37” spare tire carriers-several members have ideas there,,,OffRoadtreks, reloaded guy, Olyer(sp?). Tail gate, bed mounts, trailer hitch,,,,brands, discussions, pro’s & cons. Might be worth a look see,,,good luck,,,
Thanks. I'm definitely going to do some digging in what other here are doing.Mule007 wrote: ↑Mon Nov 25, 2024 11:50 amYou’ve probably already checked Board Index Brakes, tires, wheels for37” spare tire carriers-several members have ideas there,,,OffRoadtreks, reloaded guy, Olyer(sp?). Tail gate, bed mounts, trailer hitch,,,,brands, discussions, pro’s & cons. Might be worth a look see,,,good luck,,,
2023 Power Wagon
Previous Truck
Previous Truck
I'll see if I can figure out who he is and look into what he's done. I actually went with the AEV Procal (was here when I got home from work today) to set the tire size. Didn't know about the Tazer, but the Procal worked great to get the speedo corrected. The hardest part was hooking up the jumper from the ODBII to the green Star connector.
2023 Power Wagon
Previous Truck
Previous Truck
Here's his build thread: viewtopic.php?f=2&t=8123ldgregory wrote: ↑Mon Nov 25, 2024 8:31 pmI'll see if I can figure out who he is and look into what he's done. I actually went with the AEV Procal (was here when I got home from work today) to set the tire size. Didn't know about the Tazer, but the Procal worked great to get the speedo corrected. The hardest part was hooking up the jumper from the ODBII to the green Star connector.
Retired BLM Rig wrote: ↑Tue Nov 26, 2024 5:29 pmHere's his build thread: viewtopic.php?f=2&t=8123ldgregory wrote: ↑Mon Nov 25, 2024 8:31 pmI'll see if I can figure out who he is and look into what he's done. I actually went with the AEV Procal (was here when I got home from work today) to set the tire size. Didn't know about the Tazer, but the Procal worked great to get the speedo corrected. The hardest part was hooking up the jumper from the ODBII to the green Star connector.
