Better brakes?
Easttnrhino
Better brakes?
Post by Easttnrhino » Thu May 28, 2020 6:12 am
My 2017 has never had what I thought the best brakes and honesty in low range the brakes will stop it but they seem almost overwhelmed. Has anyone tried the z36 power stop kit and did it help or is there some other upgrades out there? Thanks
Enjoying beautiful east TN
Re: Better brakes?
Post by RustyPW » Thu May 28, 2020 8:58 am
I'm using the EBC Yellowstuff pads, Crown stainless brake lines, and Motul 660 brake fluid.
Re: Better brakes?
Post by Bill2014 » Fri May 29, 2020 1:25 pm
X2 - EBC Yellow :rockon:
Re: Better brakes?
Post by DamageWagon » Fri May 29, 2020 3:07 pm
I’ve run the PowerStops and like them. I haven’t tried the EBC’s yet.
Re: Better brakes?
Post by Reloaderguy » Mon Jun 01, 2020 9:46 pm
A few members here have posted the work they've done to their brakes. Mike Key recommended power bleeding the brakes and I kept putting it off. After nearly rear ending someone I finally got motivated enough to do it. Frankly I'm surprised how well the brakes worked with as much air came out of them. I then bled the ABS using AlfaOBD.
I also switched to Z36 pads. Each step incrementally improved the brakes but it took all of it to really make them feel better. The brakes on my truck have never been good, they're much better now although they could still be better.
Oilbrnr
Re: Better brakes?
Post by Oilbrnr » Tue Jun 02, 2020 1:00 pm
So RLG you're saying that they weren't bled from the factory?
'16 with '17 FWC
Re: Better brakes?
Post by Reloaderguy » Tue Jun 02, 2020 1:24 pm
Probably to FCA's standards but their was air in the lines.
Re: Better brakes?
Post by Bill2014 » Thu Jun 04, 2020 9:56 am
The factory may not be the only source of air - lots of shops and even individual owners have been known to skip the bleed after work is done :poke:
