Apparently Toyo 37 MT are type 99 tires in bcm
Tech said he changed the tire type to that in the BCM and speedometer matches GPS now. Presumably after the series of other things you need to do to get that to take without alarms.
- 1pieceatatime
Re: Apparently Toyo 37 MT are type 99 tires in bcm
Mine go on tomorrow for PWIM. Hoping I don’t regret the MT choice next winter...
If you think they are gonna not slip and slide around on the main roads you will be in for a treat!1pieceatatime wrote: ↑Wed Apr 10, 2019 2:31 pmMine go on tomorrow for PWIM. Hoping I don’t regret the MT choice next winter...
What in the world does type 99 even mean lol, did he just change the tire size?
Mine handled snow and ice just fine this winter.olyelr wrote: ↑Fri Apr 12, 2019 8:21 amIf you think they are gonna not slip and slide around on the main roads you will be in for a treat!1pieceatatime wrote: ↑Wed Apr 10, 2019 2:31 pmMine go on tomorrow for PWIM. Hoping I don’t regret the MT choice next winter...
It's all relative - if you've only run M/T tires on a specific vehicle, then that winter performance is the "standard".Reloaderguy wrote: ↑Wed Apr 17, 2019 9:09 amMine handled snow and ice just fine this winter.olyelr wrote: ↑Fri Apr 12, 2019 8:21 amIf you think they are gonna not slip and slide around on the main roads you will be in for a treat!1pieceatatime wrote: ↑Wed Apr 10, 2019 2:31 pmMine go on tomorrow for PWIM. Hoping I don’t regret the MT choice next winter...
Large lugs without lots of siping are not ideal in the snow...
Sometimes the internet doesn't deliver. This is one of those instances.Bill2014 wrote: ↑Wed Apr 17, 2019 12:08 pmIt's all relative - if you've only run M/T tires on a specific vehicle, then that winter performance is the "standard".Reloaderguy wrote: ↑Wed Apr 17, 2019 9:09 amMine handled snow and ice just fine this winter.olyelr wrote: ↑Fri Apr 12, 2019 8:21 amIf you think they are gonna not slip and slide around on the main roads you will be in for a treat!1pieceatatime wrote: ↑Wed Apr 10, 2019 2:31 pmMine go on tomorrow for PWIM. Hoping I don’t regret the MT choice next winter...
Large lugs without lots of siping are not ideal in the snow...![]()
The guy I pulled out of Hyalite canyon with the siped ATs didn't ask why my truck wasn't slipping or how I managed the 700 mile snow storm.
Yep, thats just it. Its all relative.Reloaderguy wrote: ↑Wed Apr 17, 2019 9:09 amMine handled snow and ice just fine this winter.olyelr wrote: ↑Fri Apr 12, 2019 8:21 amIf you think they are gonna not slip and slide around on the main roads you will be in for a treat!1pieceatatime wrote: ↑Wed Apr 10, 2019 2:31 pmMine go on tomorrow for PWIM. Hoping I don’t regret the MT choice next winter...
All I know is a good a/t tired would hands down out perform an mt on snow covered roads.
That being said, if the toyo mt is good enough, well then its good enough
Snow is such a subjective term. Are you talking snow and ice covered roads, type of snow, snow depth? My highly siped Toyo RTs are great on snow covered roads but mediocre at best in deep snow. Honestly I'd rather buy a tire for deep snow (MT outter lugs and closer inner lugs) and use chains for ice if I have too...
It's purely subjective. I think the poor snow and ice performance of MT's is overstated. This winter was particularly bad in the PNW and I had no issues. In one instance I drove 700 miles in a single continuous snow storm that was said to be the worst in 40 years. Conditions ranged from water ice to 2' of standing snow on 10" of hard packed ice.olyelr wrote: ↑Fri Apr 19, 2019 11:58 amYep, thats just it. Its all relative.Reloaderguy wrote: ↑Wed Apr 17, 2019 9:09 amMine handled snow and ice just fine this winter.olyelr wrote: ↑Fri Apr 12, 2019 8:21 amIf you think they are gonna not slip and slide around on the main roads you will be in for a treat!1pieceatatime wrote: ↑Wed Apr 10, 2019 2:31 pmMine go on tomorrow for PWIM. Hoping I don’t regret the MT choice next winter...
That being said, if the toyo mt is good enough, well then its good enough![]()
Having worked in Zak's area I think siped aggressive AT's or hybrids is probably the best for his conditions. Portland gets ice storms that shut the city down. I've been there after the area got 1/2" of water ice, studs would have been best but that's a pretty expensive option given how limited the use would be.
I have no problem in town. But I think I need bigger lugs and more aggressive tread for deep snow. I'm really thinking about Cooper STT Pros after seeing them in person. I think the closer alternating 3 lug center will hold enough snow to add traction while keeping the deep lugs to clear. Idk... deep thoughts... and I won't execute until September or October... soo... months of me flip flopping around...Reloaderguy wrote:It's purely subjective. I think the poor snow and ice performance of MT's is overstated. This winter was particularly bad in the PNW and I had no issues. In one instance I drove 700 miles in a single continuous snow storm that was said to be the worst in 40 years. Conditions ranged from water ice to 2' of standing snow on 10" of hard packed ice.olyelr wrote: ↑Fri Apr 19, 2019 11:58 amYep, thats just it. Its all relative.Reloaderguy wrote: ↑Wed Apr 17, 2019 9:09 amMine handled snow and ice just fine this winter.olyelr wrote: ↑Fri Apr 12, 2019 8:21 amIf you think they are gonna not slip and slide around on the main roads you will be in for a treat!1pieceatatime wrote: ↑Wed Apr 10, 2019 2:31 pmMine go on tomorrow for PWIM. Hoping I don’t regret the MT choice next winter...
Well, a mt can perform better that an at or even a strickly snow tire in certain snow conditions, mainly like deep snow/powder situations.
But I dont care what anybody says... on most road travel situations i encounter, mt’s are hands down far worse that an at with siping. I would however like to try a siped mt... thinking that may be the best of both worlds?
