Just got my PW it has 3" spacer rear lift with rough country N3s. I want to go back to stock length/ hight. The driveshaft hits the cross member they didn't change the sway bar links. 12" links seem short, the bar sits really high. I'm afraid it will invert. ( probably not until the driveshaft breaks 🫣)
Any help is appreciated.
Sent from my SM-G986U using Tapatalk
Anyone know the stock shock length 2022 PW
Re: Anyone know the stock shock length 2022 PW
Welcome to the forum.
I can't help as I had an '08. Someone will be along with the answer.
Welcome to the forum,,,,Enjoy,,!!
Updates: Jasper Remfgr’d 5.7 Hemi Engine; Open Range AT 35x12.5 x17 MP3 10 ply E tires; Moog HD U/L front axle ball joints & wheel bearings; new link, sway, y bar & bushing assemblies; fuel pump; ETC; AC exhaust fan & compressor;1 ton HEMI transmission cooler; OEM radiator; front pinion seal & bearing; Denso 180-amp alternator; Interstate 850 CCA HD battery; water pump, serpentine belt, Bilstein 2 5100 shocks/HD steering damper; F&R locker motors,sensors/u joints; 3" Magna flow cat back rear exit dual exhausts; Performance Brake/slotted rotor/caliper/pads/brake lines
It looks like the factory rear shock part number for your truck is 68450200AD. Unfortunately I can't find any specs for it, just pictures that show that it's a Bilstein shock that comes stock on the PW.gledel6257 wrote: ↑Tue Apr 09, 2024 10:07 pmJust got my PW it has 3" spacer rear lift with rough country N3s. I want to go back to stock length/ hight. The driveshaft hits the cross member they didn't change the sway bar links. 12" links seem short, the bar sits really high. I'm afraid it will invert. ( probably not until the driveshaft breaks 🫣)
Ok. Found it for anyone interested. Rear shock extended length is 24.37" compressed is 16.56
gledel6257 wrote: ↑Tue Apr 16, 2024 5:19 pmOk. Found it for anyone interested. Rear shock extended length is 24.37" compressed is 16.56
