BDS 2” lift and 37” tires on 2020 PowerWagon
39Saint
Post by 39Saint » Sun Feb 16, 2025 1:58 pm
:excited: I just had the BDS 2” Suspension lift installed and my 37” Yokohama Geolandar tires barely brush the bottom of the fender well plastic on full turn… is there a body weld under that cover that I can trim? Still snowing here in PA so I don’t have an opportunity to take that off and look.
TommyG
Re: BDS 2” lift and 37” tires on 2020 PowerWagon
Post by TommyG » Sun Feb 16, 2025 7:58 pm
Good video on trimming everything. You can hit the pinch weld with a grinder/flap wheel if you are still making contact.
https://www.youtube.com/watch?v=ZrbWcMZKmxk
Post by adeluca73 » Wed Feb 19, 2025 12:21 am
I ran 37’s on my 2014. Before & after installing the full Thuren suspension system. I had very minor rubbing @ full-lock before , none after.
    - Strip LEDs
  • Garmin Power Switch Powering:
Post by KevinABQ » Tue Apr 08, 2025 2:38 am
I put AEV wheel with the right offset in and didn’t have to trim anything.
