I have a 2018 PW. I am looking for information on the center rear shock that goes from the rearend to the frame. I need the Bilstein part number.
TIA!
Rear Center Shock
Re: Rear Center Shock
viewtopic.php?f=13&t=2348&start=150#p66871
This guy replaced with 3 of the shocks to reduce the rear wheel hop
Ram calls it the "Axle Beam Damper", current OE part #68414247AB. Take that number and put it into Rock Auto's part number interchange and it brings up Bilstein #24274395 or #24-274395.
I hope this helps.
Yes it does thanks! Going Fox all the way around and wanted to change this one out too.
