Smart Bar bolts
Smart Bar bolts
Does anyone know where I can buy, or the part number for, the three bolts that hold the electronic actuator module to the bar? After three years mine have disappeared and I need another set.
Re: Smart Bar bolts
I don't know the stock part number. The stock bolts have a retained loose flat washer, but I haven't had any success finding those in a bulk supply. I do have these. They're grade 10.9 M10 X 1.5 X 30mm black phosphate with a flat flanged 15mm hex head. Let me know if you want them.
Re: Smart Bar bolts
The factory part number is 68044409AA.
Re: Smart Bar bolts
Thanks. I'm going to try to source them locally first. I have one of the bolts and will be able to make it work short term.Retired BLM Rig wrote: ↑Mon Jun 15, 2020 11:17 pmI don't know the stock part number. The stock bolts have a retained loose flat washer, but I haven't had any success finding those in a bulk supply. I do have these. They're grade 10.9 M10 X 1.5 X 30mm black phosphate with a flat flanged 15mm hex head. Let me know if you want them.
