Thurens newer fox 2.0’s?
joeschmidt
Just wondering if anybody has upgraded from Dons white shocks to his fox 2.0’s???
Re: Thurens newer fox 2.0’s?
That is going to be an improvement but probably not a major one. If you were coming from stock shocks it would be worth it. Coming from Overland’s, I’d suggest going to a bigger shock if you’ve felt what a better shock does to the truck and you want more performance. The new aluminum bodied 2.0 is better than the Overland but it doesn’t touch what the 2.5 size shock can do.
- Pasopwagon
I put mine on the rear this morning doing the fronts tomorrow with the XS coils. Check out my build thread.
Acroweld powerwagon build
https://r.tapatalk.com/shareLink?share_ ... are_type=t
