Is there a spring available for the rear in order to maintain the factory rake with the Thuren 1.5 inch lift?
Factory Rake
- Oilbrnr
Re: Factory Rake
Yeah. AirLift.
You can ask Chris, but Don felt their other rear spring options a couple months ago (think for the Cummins) was too stiff, even in my application that has a lot of weight in the back. Shell, fridge, rack, solar, extra battery etc.
'16 with '17 FWC
- Punishher7
Factory Rake
Maybe I should have been more clear. I want to keep the factory rake while unloaded and not towing. I’m not a fan of the nose high look trucks get when leveled. I appreciate the info though.
Re: Factory Rake
1" rear spring spacer.
Re: Factory Rake
What he said. I shoulda added that spacer from the start. I added it later with just the front springs and still have it installed with Kings and full Thuren.Reloaderguy wrote:1" rear spring spacer.
Re: Factory Rake
1” coil spacerPunishher7 wrote:Is there a spring available for the rear in order to maintain the factory rake with the Thuren 1.5 inch lift?
- Punishher7
Re: Factory Rake
Thanks gents!
