Post
by TankerZak » Fri Jun 30, 2017 12:57 am
MikeKey wrote:5th Wheel I think you can have a greater tongue weight. They also hitch easier (to some people) but they are a bitch to maneuver. Pull behind can be difficult to hitch (I suppose for some, not me) generally takes turns and corners better than a 5th wheel and is easier to maneuver and back into a spot. Pull behinds usually are smaller, and you have to watch tongue weight to make sure your truck and hitch can handle it.
There was a guy at PW in Moab who pulled a 5th Wheel with his 2015 PW Laramie. Said it did great. ¯\_(ツ)_/¯
I pull a 27ft Airstream, tows beautifully with the PW.
Mine tows great except for two things. Higher engine rev uphills compared to my old Duramax. But that is just the nature of gas engines. Power bands are at a much higher rpm than diesels.
And if i go to fast with or without the trailer i feel like the tires get squirrly. I think that has to do with 35s on 17s and so much sidewall. When it starts to flex it just... flexes.
And that is me being SUPER nitpicky.
