Post by Colibri » Mon May 07, 2018 6:13 pm
YES!!! There is none more black
Post by Mule007 » Mon May 07, 2018 6:18 pm
Looks good!
Chromolykid
Post by Chromolykid » Mon May 07, 2018 7:02 pm
Haha she’s actually Max Steel, beautiful in the sun but I try to leave a layer of dust on to hide the desert pinstriping.
“Furiosa”
2016 Power Wagon
White Knuckle Sliders
DOR Steering Brace
Thuren Stage 1 KING 2.5’s
Thuren Coils Front & Rear
Dethloff Swaybar Spacers
AEV Procal
Post by nts007 » Wed May 09, 2018 1:06 am
My fav Moab pic
Post by olyelr » Wed May 09, 2018 7:40 am
Just look at that oil burner go! :D
:rockon:
Post by nts007 » Thu May 10, 2018 12:02 am
:rockon:
And go it did
Post by PWJouster » Thu May 10, 2018 9:37 am
Chromolykid wrote:
Mon May 07, 2018 4:12 pm
Okay. :D
instantly a new truck....sorry but i despise chrome, and you just nailed it! great job and tell us you dont feel like it its a huge improvement!
Post by Low_Sky » Tue May 15, 2018 1:16 am
On Saturday I linked up with wilsonsinak for a wheeling trip with him and some (most?) of his co-workers. We were in the Wagons, everyone else was on a SxS or four wheeler. It was a 25 mile haul out to the Knik glacier, with just enough mud and winching to make things interesting on the trail. Did a little bit of gawking at the splendor of nature, and headed back to the trailhead; almost a 10 hr round trip.
I had a couple friends riding with me, the photos in this post are by my friend Mike (https://www.instagram.com/brocious).
Post by Low_Sky » Tue May 15, 2018 1:21 am
And a few of my photos. I took a lot less, being busy with driving duties.
Post by OffroadTreks » Wed May 16, 2018 5:12 pm
yellowranger1
Post by yellowranger1 » Wed May 16, 2018 5:38 pm
Shit happens when you party on the rocks!
Glad that didn't happen at speed! I wan't thrilled when I re-centered my wheel after the lift and saw how much it was threaded out... Synergy has some prototype steering kits floating around out there for our trucks that should add some strength when available. How long before the ram-assist is installed??? 8-)
Post by Low_Sky » Wed May 16, 2018 5:47 pm
Is that tie rod bent too?
yellowranger1
Post by yellowranger1 » Wed May 16, 2018 6:01 pm
Bent is such an ugly word... "Contoured"
Post by Low_Sky » Wed May 16, 2018 6:46 pm
"Strengthened by cold working"?
Post by Colibri » Wed May 16, 2018 7:59 pm
Navigating the rocks by Braille
Post by olyelr » Wed May 16, 2018 8:14 pm
DOR has a kit out...
http://store.dodgeoffroad.com/Dodge-Off ... p_166.html
In fact, this steering is bigger than what most rock bouncers and monster trucks use.
Post by OffroadTreks » Thu May 17, 2018 12:12 am
It bent like hot butter with a bad line on the Golden Crack this year. I attempted to relocate when I should have stayed put and snapped it. Take a look at this >>>
We pulled a spare unit to get off the trail. Then modified this, sleeved it and reinstalled it to get back home. Have a new replacement.
DOR is currently the only one with a full kit for the 2014+ trucks. Synergy supposedly has a kit coming.... sometime ¯\_(ツ)_/¯
And I do not know if Thuren has any plans.
So right now, I'm researching. I am told, that spot, is where it breaks for A LOT of people.
Post by DamageWagon » Thu May 17, 2018 2:25 am
I once ran a DOR steering kit for two weeks.
Post by DamageWagon » Thu May 17, 2018 2:26 am
Seemed to be the theme this year :doh: :sick:
Chromolykid
Post by Chromolykid » Thu May 17, 2018 12:56 pm
Looks awfully familiar!
“Furiosa”
2016 Power Wagon
DOR Steering Brace
AEV Procal
Mule
Post by Mule » Wed May 30, 2018 7:26 pm
Finally got around to drilling out the bolts on the skid plate/frame that Firestone fucked up when they did the fuel pump replacement.
Gave up and drilled two new holes just above the old ones. :\
Got it shoved under, halfway-secured....
...and that's when I realized they broke three more bolts they didn't tell me about. Some more drilling/grinding/swearing...
Glad I picked up some extra bolts at home depot... :( Hopefully all set for a while now.
....especially since I'm playing hide-and-seek with a bad bearing in the moto engine....
Think it's either head/cam (what i'm hoping for, cheap/easy) or counterweight (complete teardown/rebuild). Stator, countershaft, and everything under the clutch cover looks good.
Post by DamageWagon » Wed May 30, 2018 8:44 pm
Do the dirt bikes have the same problems the LC4’s had with the crappy Turkish cam bearings??
Post by Reloaderguy » Thu May 31, 2018 12:21 am
Hydro assist would relieve the stress on the draglink but cranking on the steering in a crack would probably just break something else.
Mule
Post by Mule » Fri Jun 01, 2018 2:57 am
Most of the reason mine has issues is because it's got about 30,000 miles on it :rofl:
Replaced most of the bearings a few years back, one of the crank bearings got replaced 2yrs ago.
If it's a rocker/cam bearing (wouldn't be the first time i've lost one of those), that should be a real easy/inexpensive/quick fix. Anything deeper and I might as well throw in a new piston, run a hone through the cylinder, new gasket set, etc.... Image
Ran the bike out of fuel this morning, thought I killed it... forgot to refuel after yesterday's run into denver. Whoops. :rofl:
Parking garages aren't Power Wagon (won't clear height) or dirt bike (sensors don't detect it) friendly.
After rolling forwards/backwards for about 5mins to find the sweet spot in the entry-gate loop, it was a weird "hold the bike up in this exact position so it detects me" and reach over to press the button on the machine that's just baaaaaarely within arm's reach so it'll shit out a ticket and open the door/gate to let me in...
....going out, I couldn't find the spot where the loop would pick me up so I could stuff the ticket into the machine. Buzzed the attendant, and apparently the mic on the kiosk was broken. "Hello, can you hear me? Hello?" ... finally gave up and just rode around the gate. :thppt:
Aaaaaaaaaaannnnnnnnnnnndddddddddd.... on the way home last night....
He didn't like my license plate. Mounted vertically (if it's horizontal, it gets ripped off in the trees, btdt), and ... well, it's a dirt bike that I ride like a dirt bike, so it's not exactly in pristine condition. I guess there's no laws broken, but being "hard to read" is grounds for a stop... whatever.
Hodgepodge
Post by Hodgepodge » Wed Jun 06, 2018 2:18 pm
Pictures of my neighborhood adventure:
Hodgepodge, Klein, Texas
2016 RAM PowerWagon
37” Toyo Open Country MTs
Amp side steps
