Post
by TwinStick » Fri Mar 07, 2014 6:55 pm
Mexican Import
Post
by Mexican Import » Fri Mar 07, 2014 7:13 pm
Better not use that thing on a hill... or its gonna be a ski trip for your truck if not worse. Better get one with crampons.
Post
by TwinStick » Fri Mar 07, 2014 7:26 pm
Really though, why would you use ANY jack on a hill ?
verdesardog
Post
by verdesardog » Fri Mar 07, 2014 9:38 pm
A base with teeth instead of a ski would be more useful.
I'm still thinking about the hilift base I made. My original idea was to put four points on it but got lazy and left it as a channel:
Post
by TwinStick » Sat Mar 08, 2014 9:45 am
That will work fine just the way it is. If you really want to, it would be easy enough to make shark teeth in the channel with an angle grinder/cutoff wheel.
Pit Slave
Post
by Pit Slave » Sat Mar 08, 2014 11:19 pm
yup, it's used mostly in sandy and soft applications where a normal jack would sink into the ground (much more dangerous).
Mexican Import
Post
by Mexican Import » Mon Mar 10, 2014 1:04 am
I have been stuck on a hill and used a jack to keep my sheet metal out of trees, and a few other times like steep washed out roads. I don't really like using a jack on a hill but sometimes it's the only option. I'm not saying this thing is useless I just wanted to point out that a sled isn't my first choice when it comes to something I want to stay where I put it and not spit out.
Fireman78
Post
by Fireman78 » Sun Mar 23, 2014 5:33 am
Cool. I look at is a yet another arrow to be carried in the recovery quiver. Not "Choose One".
