Post by cruz » Tue May 14, 2013 8:17 pm
GunniPWguy wrote:That looks like a nice mod for the Pop up Cruz. It is fairly annoying to have it turning on and off all night. So I assume the battery drain is from the electronic ignitor cycling on every 5-10 minutes on the furnace? How bad is the off gassing of carbon monoxide with those catilytic heaters. I like to know that when i go to sleep there is a good chance I'll wake up in the morning. :ugeek:
Both of the furnaces in the camper and the Coleman tent trailer are the same type and have a blower fan, and thats the noise that bothers me most, its also the major cause of the battery drain, the ignitor only works for a second or two vs the blower which runs constantly. As far as the catalytic heater is concerned it is silent and odor free. They recomend that you leave a window or vent open a couple of inches when operating so as not to deplete the oxygen supply. I never run the heaters or furnaces when I'm sleeping anyway so that has never been a problem for me. Seeing as a tent trailer is far from being airtight that works for and against you, ventilation is not a problem, but keeping the heat inside is.
The furnace is below the sink and stove
Juday
Post by Juday » Wed May 15, 2013 5:15 pm
TrueCowboy426 wrote:Power Wagon and the Fargo:
Nice Pilothouse! I got one myself, too!
2012 RAM Power Wagon
chromedragon
Post by chromedragon » Mon May 20, 2013 1:11 pm
I posted my PW early on but she was on pavement so here are some in what is a more natural habitat for our beloved trucks.
Special Licenses:
FAA Airframe and Power Plant
FCC Technician (Ham) KK6YCI
Robert A. Heinlein
Post by 2wagons1driveway » Tue May 21, 2013 4:18 pm
Pennies wrote:Here are a few of mine.
Dude I love the tent where did u get that?!
Dawizman
Post by Dawizman » Sat May 25, 2013 9:30 pm
Did a little bit of work today. Hauled some dirt today for a bike track my buddy is building on his property. Trailer is 14,000lb gvwr with a 9800lb load capacity. We loaded it up full of damp clay and made ten trips today. It was only a couple miles up the road. The power wagon pulled the trailer pretty awesome. Got to use the lockers once we got to his yard.
Dawizman
Post by Dawizman » Sun May 26, 2013 12:06 am
Dumping dirt...
stubiePW
Post by stubiePW » Sun May 26, 2013 2:13 pm
Awesome. Dump trailers are awesome! We have one at work best thing ever
bstefanic
Post by bstefanic » Sun May 26, 2013 6:46 pm
Getting a little sifted dirt from on old mine by the house
vanished
Post by vanished » Mon May 27, 2013 7:57 pm
Weekend camping trip. :)
vanished
Post by vanished » Wed May 29, 2013 9:21 pm
Getting some hay...
nrooney21
Post by nrooney21 » Fri May 31, 2013 10:52 am
Well since the PW has been at the dealer for the last few days, we had to resort to taking the Chevy Sonic to Southern Utah to go camping. It doesn't flex as well as the wagon, but 44 mpg sure is nice. Ha ha
Sent from my SCH-I605 using Tapatalk 2
Pit Slave
Post by Pit Slave » Mon Jun 03, 2013 1:52 pm
Came across a pic today from a computer I hadn't logged into for a long time. Yes that's you Eric following me before the mods. lol
sent from my telegraph using Tapatalk too!
VA_Wagon Man
Post by VA_Wagon Man » Mon Jun 03, 2013 5:03 pm
Yep, both in stock form. A distant memory.....lol:lol:
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
Post by TwinStick » Fri Jun 07, 2013 12:10 am
cruz wrote:
GunniPWguy wrote: Camping with a heater is awesome! It got down to 25°F at night.
Nice Gunni ' . The things that I didn't like about the heater in my Coleman tent trailer was ...
1- the noise of the fan
2- the constant on & off cycling
3- the drain on the battery
So I installed a wall mount catalytic heater , http://www.amazon.com/dp/B000BUV1RK/ref ... B000BUV1RK
now I turn on the furnace and in a few minutes after the trailer is warm I shut it down and switch to the catalytic heater to maintain the warmth, its is nice and quiet with no battery drain.
In my camper I've been using a portable heater , http://cheaperthandirt.net/product/41225
to do the same until I get around to installing one in my camper. The only drawback to the portable one is having to use disposable cylinders instead of the bulk tank.
When i can't plug into power & want to conserve propane & it is cold out, I have a 1300/1500 watt electric heater that i use. I made sure to get one with a good amount of safety features. If it gets too hot, it shuts down instantly until it cools, if it tips forward, backwards, sideways hardly at all, it shuts off immediately. I use our Honda EU2000i to run it if allowed to do so. It has heated our 30' toyhauler numerous times all by itself, all night long. Works perfect. Absolutely zero fumes. I have a Big Buddy catalytic heater but can't use it. Whatever it gives off just kills me right away. Eyes water & tear, & instant breathing problems. Yes, we have 3 roof vents cracked open & an access door down low cracked open.
For refilling your own 1 lb propane cylinders, i can highly recommend one of these: http://www.harborfreight.com/propane-bo ... 45989.html
We have one & it works awesome. You just have to refrigerate the 1 lb bottle for about 20 min, screw it on & invert the 20 lb cylinder. It has saved the day numerous times when cooking while camping. :rockon:
bstefanic
Post by bstefanic » Sat Jun 08, 2013 10:19 pm
Dynatrac's finally going in
Prairidawg
Post by Prairidawg » Tue Jun 11, 2013 8:56 pm
Finally time to try out my new ( to me ) boat!
It has an indicator that tells you how much time you can run with the current amount of fuel in the tank, and the throttle position. With a full tank(39 gallons) at WOT it says I have 2 hours left! Don't know which burns more gas, the boat or the truck!
GunniPWguy
Post by GunniPWguy » Wed Jun 12, 2013 10:56 am
That is a sick set up you have there Prairidawg!
Prairidawg
Post by Prairidawg » Wed Jun 12, 2013 9:04 pm
Thanks!
GunniPWguy
Post by GunniPWguy » Fri Jun 21, 2013 6:52 pm
Contemplating heavily modifying my tow behind pop up camper to slide in/on the back of the PW. Even though it is a high clearance tow behind, it cannot go places the PW can. Can't afford a new truck camper so this is my latest hair brained scheme. It is basically a brand new 2008 camper. My wife is on-board as long as it works. Don't flogg me too hard. :rofl: What do y'all think? :shock:
photo chopped in down position
photo chopped in up position
stubiePW
Post by stubiePW » Fri Jun 21, 2013 8:10 pm
I love it. Use what ya got!
Post by cruz » Sat Jun 22, 2013 11:24 am
GunniPWguy wrote:Contemplating heavily modifying my tow behind pop up camper to slide in/on the back of the PW. ...... What do y'all think? :shock:
In all honesty, sell the tent trailer and buy a used camper. " heavily " might be an understatement .
GunniPWguy
Post by GunniPWguy » Mon Jun 24, 2013 10:09 am
:idea: Yea I came to my senses already. Pipe dream.
wagonfarmer
Post by wagonfarmer » Mon Jun 24, 2013 10:22 pm
Just having some fun on the farm the other day. All was going well until we went downhill and the hay tipped forward onto the tailgate. :doh:
2006 QC Power Wagon, BFGoodrich AT2
Flip2336
Post by Flip2336 » Sun Jun 30, 2013 3:41 pm
Kinda like her owner, cleans up alright...
Post by 2wagons1driveway » Sun Jun 30, 2013 9:55 pm
some pictures of the new 4" bds la kit I just installed
