CEL P0740
Posted: Fri May 16, 2025 10:17 pm
2018 Power Wagon with 68k miles. Getting CEL with the P0740 code. No other codes present. Truck runs and shifts fine, no shudder, not hunting gears, shifts thru all gears as it should, RPM's are normal, no change in fuel economy.
Based off of research it could be a few different things, however there seems to be noticeable symptoms along with the code.
Fluid level is correct, fluid is clean/no burnt smells.
I have a feeling if I bring it to a trans shop they will want to do a full rebuild. I'm just not convinced it needs a rebuild being as if you did not see the CEL on you would not be able to tell that something may be wrong with the transmission.
Anyone else experience this or have any insight?
