Rear drive shaft replacement?
- Model Year: 2017
I have a stock 2017 PW, and would like to have either a steel rear drive shaft or a thicker walled aluminum ( local shop said that is my only option). Who is the go to on driveshafts and what have some of you all done? I have emailed Tom woods. Thanks
Enjoying beautiful east TN
Re: Rear drive shaft replacement?
the large diam aluminum driveshafts have alot of bending and torsion strength but almost no impact resistance. if your wanting to use a more impact resitant shaft so you can crash it on boulders, youll likely just break the tailshaft off the tcase
Driveshaftspecialist.com
I got their HD aluminum rear shaft and it makes the factory part look like a cheap knockoff toy.
If I remember correctly I went with the 1480 u joints. I had to notch my rear crossmember for extra droop travel when I did the bypasses and upper shock mounts out back, so it just clears. Stock travel might fit without trimming but I don’t know for sure
