Transfer case swap
Posted: Fri Mar 15, 2019 1:31 pm
I've researched this and haven't found much information. Is it possible to swap the NV241 OR Rock-trac (the 4:1 case in the Jeep Wrangler Rubicon) into a power wagon with the BorgWarner 44-47 transfer case? I know you would need a new rear drive shaft without and slip yolk and possibly a new front with a different length shaft, but are the electronics compatible for a more or less plug and play? Could a harness be made to mate the ram electronics to this transfer case as they are both in Chrysler products? Given the similarities of the 45RFE and the 66RFE, are the output shafts and the mounting flange the same? With all that said, can the NV241 OR Rock-trac handle the power output and towing capability of a Power Wagon? The NV241 have been used in lots of older Dodge trucks with the RFE transmission although, from what I've read, the case on the Rock-trac is significantly different.
The reason for this topic of discussion is, could this be another option instead of re-gearing or as an added gear reduction for off-roading? With the new power wagon having a much lower crawl ratio, this could be an option to level the playing field without a transmission swap or steep axle gears. This seems to be a common swap for lots of jeeps to increase crawl ratio and other companies have done similar swaps for other brand trucks.
Thanks
Thanks
