Rear Locker
Speed6
Rear Locker
Post by Speed6 » Mon Mar 25, 2024 9:22 pm
My 2005 Power Wagon rear diff locker shorted out and fried [Insert burnt Electrical wires smell here] what are people doing replacing with factory locker [can you get replacement] or used locker, I was thinking AAM11.5 off a diesel truck regear 4:56 and Detroit Locker or Grizzly, any ideas.
Re: Rear Locker
Post by Mule007 » Mon Mar 25, 2024 9:43 pm
Check w retired BLM rig,,,,part is pretty scarce but he might have some ideas. He helped me when I was having that problem a +/- couple of years ago
Updates: Jasper Remfgr’d 5.7 Hemi Engine; Open Range AT 35x12.5 x17 MP3 10 ply E tires; Moog HD U/L front axle ball joints & wheel bearings; new link, sway, y bar & bushing assemblies; fuel pump; ETC; AC exhaust fan & compressor;1 ton HEMI transmission cooler; OEM radiator; front pinion seal & bearing; Denso 180-amp alternator; Interstate 850 CCA HD battery; water pump, serpentine belt, Bilstein 2 5100 shocks/HD steering damper; F&R locker motors,sensors/u joints; 3" Magna flow cat back rear exit dual exhausts; Performance Brake/slotted rotor/caliper/pads/brake lines
Re: Rear Locker
Post by Retired BLM Rig » Tue Mar 26, 2024 1:14 am
Here's the part # 5175302AB
Steve White Motors shows one in stock. You would need to confirm with them, everyone else shows discontinued. :cry:
Here's a complete used rear axle assembly on Ebay.
I can build a bypass system that will completely replace all of the rest of the electrical and still use the factory switch to control the lockers.
Re: Rear Locker
Post by Mule007 » Tue Mar 26, 2024 7:34 am
In parts for sale recently Redman sold his wrecked 2005 for parts & before sale had noted the front & rear axles were good,,,might be able to find out who bought it & see if they’d be willing to sell that part assuming it wasn’t damaged. But can’t go wrong w “Retired’s “ Able products. He knows our wagons & these issues very well & won’t steer you wrong. Good luck!
