Locker Bypass Rebirth
jsims006
Re: Locker Bypass Rebirth
Post by jsims006 » Fri Jul 26, 2019 3:28 pm
Well specifically what I meant was why the safety features exist when you still cant lock it down and disconnect even after meeting them.
Post by Bill2014 » Fri Jul 26, 2019 3:55 pm
When all the criteria in the logic is satisfied, the locker will be energized to engage (your light(s) will still be blinking). When alignment takes place, AND the locker is energized, AND the locking mechanism is not bound up and can move, the dog ring pushes towards the locking slide gear and the axle shafts are locked together. Once this happens, the locker light remains on solid confirming that you are locked.
:rockon:
jsims006
Post by jsims006 » Tue Jul 30, 2019 9:21 am
:rockon:
Yeah I understand how e-lockers work. I just dont understand why the ram logic is so intrusive. Theo nly thinig I can think of is for warranty coverage. So lets make it aggravating to engage and force everyone to use fortune tellers before they go out in the woods first.
In any case I just got my able bypass so I wont have to deal with that anymore.
jeffisphree
Model Year: 2019
Post by jeffisphree » Sat Aug 17, 2019 3:08 pm
Will this bypass work on a 2019?
Post by Retired BLM Rig » Sat Aug 17, 2019 11:34 pm
No, the 19's don't need it. Ram finally allowed locker function in all transfer case ranges starting this year. I haven't heard a single complaint yet regarding locker engagement on the new trucks.
Post by olyelr » Sun Aug 18, 2019 10:04 am
Maybe with the new switches/setup/design they finally got it figured out.
cb1987
Post by cb1987 » Mon Aug 19, 2019 10:56 pm
blm i had a question on the bypass. using it yesterday in 4hi the rear locked as normal. after turning the knob to front /rear at a very slow speed the front seemed to lock as normal but there was a rapid clicking sound from the front passenger side, presumably under the hood where the box is located. the clicking didnt stay constant and slowed then got more rapid. after a minute or so it seemed to stop. is the clicking a sign that the relays need adjusted on the front ? honestly i didnt check the adjustment at install, so maybe it was on the borderline needing adjusted
Post by Retired BLM Rig » Tue Aug 20, 2019 12:47 am
Yes, that's a sure sign that it's time to make an adjustment. The procedure is simple and outlined on page #6 of the installation instruction. If you need me to send you another copy of the instructions, just say the word.
cb1987
Post by cb1987 » Tue Aug 20, 2019 1:29 am
thnanks ive got the manual. the bypass sure beats the hell out of the crap stock system :lol:
