Mopar Ignition Coil Redesign
Post by coder » Fri Feb 01, 2019 10:07 pm
After 175k miles I replaced my original 07 ignition coils today with a fresh set of mopar coils and was surprised to see they have been redesigned.
They added a small insert presumably to improve electrical current flow between the coil and the spring to the plugs I personally have not seen this on any other coil. Not a huge deal but kinda cool IMO.
These same coils are used on all Hemi's the 5.7, 6.4 and the 6.2 supercharged Hellcats and Demons.
- 2007 Ignition Coil PN 56029129AB (top)
- New Ignition Coil PN 68238603AA (bottom)
NovA ProspekT
Re: Mopar Ignition Coil Redesign
Post by NovA ProspekT » Sun Mar 17, 2019 10:10 pm
Did you notice a difference after replacing the coils?
Post by coder » Mon Mar 18, 2019 7:41 pm
Yes, I did actually. I felt a slight bump in throttle response, low end torque and MPG, overall the engine feels smoother. I don't know if it was because I replaced coils with a lot if miles on them (even though there were no codes/issues) or the new coils are better.
AlaskaTRX
Post by AlaskaTRX » Mon Mar 18, 2019 11:17 pm
Did you replace the plugs or anything else at the same time?
Post by coder » Tue Mar 19, 2019 8:29 pm
I changed my plugs about 3-4 months earlier so when I did the coils it was just the coils.
NovA ProspekT
Post by NovA ProspekT » Thu Apr 04, 2019 10:34 pm
hmmm...I wonder if the performance increase is from a "better"/newer-design coil or if the old coils were just "worn out"(do they wear out?).
Post by coder » Fri Apr 05, 2019 5:19 pm
Coils do wear over time they develop increased electrical resistance until the voltage drops below spec or dies and throws an error code. However OEM Hemi coils are known for lasting a long time and being able handle much more than factory HP.
